09-11-2009, 11:21 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | SL2 / SL3 contact service repair CHEK problems that accurs r .. mainly these r after unlocking CONTACT SERVICE FAILED TO READ NOKIA LOGO AND OFF here i m writing a simple solution to chek whether the problem can b solved FREE .. i mean without RPL.. this problem occurs when 1.SOME PM FEILDS R CORRUPTED ( CAN B REPAIRED ) 2.SP DATA IS CORRUPTED ( CAN B REPAIRED IN SOME CASES ) OR NEED RPL 3.IMEI GOES 12345????? NEED RPL IN FIRST CASE ALL U NEED TO DO IS AUTH PM (SX4) AND WRITE GOOD PM IN SEC CASE THE AUTH PM (SX4) WONT WORK COUSE THE SP AREA IS CORRUPTED . THERE IS A SUPERDONGLE KEY IF ITS CORRUPTED ALL U NEED IS GOOD RPL.. IF THE SUPERDONGLE KEY IS FINE U HAVE TO SIMPLY WRITE THE 120PM FIELD AND ALL B FINE. NOW HOW TO CHEK WHETHER SUPERDONGLE KEY IS CORRUPTED OR NOT THNX TO oOXTCOo FOR THE BRILIANT TOOL J.A.U.http://forum.gsmhosting.com/vbb/showthread.php?t=781730 ufs / jaf box CAN B USED .. open soft connect box goto BB5 TAB there u ill see a LOCAL SX4 AUTH button connect fone and press button now see info if the SUPERDONGLE KEY damaged auth. fail..... if its ok come back to MAIN TAB select ur operater press CALC. 120PM ... than WRITE 120 PM... voila fons O.K. BR .:KHALIFA:. |
The Following 9 Users Say Thank You to .:KHALIFA:. For This Useful Post: |
09-11-2009, 12:54 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | im testing this software 4 repair sim lock in 5130 but cannot to solve simlock data thanks frome info |
The Following User Says Thank You to soshan For This Useful Post: |
09-11-2009, 13:28 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: HWKBOX,MX-KEY,CYCLONE SL3 ;-)
Member: 217461 Status: Offline Thanks Meter: 150 | hi, how can I force in test / local mode in usb? with my N85 I can only make the flash dead usb first restarts every minute after writing pm 120 went into service contact thanks for the help. THANKS, B.R. |
09-11-2009, 13:42 | #4 (permalink) |
Member: 275631 Status: Offline Thanks Meter: 408 | wats the history of phone... to enter local mode u need fbus cable... u doing all procesure with usb? |
The Following User Says Thank You to .:KHALIFA:. For This Useful Post: |
09-12-2009, 08:51 | #7 (permalink) | |
Member: 217461 Status: Offline Thanks Meter: 150 | Quote:
hi , now goes to local / test mode after flash dead usb, I did flash with dead usb jaf cracked because in normal mode was not in flash mode crashes, a friend of mine with FBUS I repaired the software and flash firmware e71 308 pm to Zule unlocked but the phone is restarted and had the config key ruined so I decided to write pm 120 ae is now back in contact service | |
09-12-2009, 10:32 | #8 (permalink) | |
Member: 275631 Status: Offline Thanks Meter: 408 | Quote:
if u want to repair from this condition in which phone is right now.. u can read the first post.. hope it will help br .:KHALIFA:. | |
09-12-2009, 11:45 | #9 (permalink) | ||
Hi .:KHALIFA:. my N85 is unlocked native is in contact retailer for flash in dead usb with jaf cracked ,only flash in dead complete in normal mode no. i have pm 308 backup by jaf i have not fbus cable only usb cable | ||
5220 contact service-repaired sd-write pm-still in contact service | zonetrichur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-07-2010 13:21 |
SL3 Contact Service not repaired with rpl | dannyogolo | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 09-24-2009 07:34 |
Bb5 contact service reapir chek | .:KHALIFA:. | Nokia Base Band 5 ( BB-5 ) | 5 | 09-15-2009 18:27 |
Bb5 sl2/sl3 contect service and unlocking solution post here pm120 | Nurettin Duman | Cyclonebox | 4 | 05-10-2009 22:16 |
Bb5 sl2/sl3 contect service and unlocking solution post here | Gsm Soft | Cyclonebox | 12 | 05-10-2009 10:54 |
