Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-27-2009, 02:39   #1 (permalink)
UHK
UHK's Avatar
Member: 13737
Sonork: 100.100725
Thanks Meter: 191
***sl3 bb5 imei 12345? Repair solution with video***
*** SL3 IMEI 12345 SOLUTION WITH RPL ***
YOU NEED RPL IN CASE
IF YOU HAVE NO IMEI BACKUP
ERASE FLASH
KILLED BY FREE SOFT AND IMEI 1234
ETC
OR IF CLICK HERE
SO FOLLOW SIMPLE STEPS FIRST BEFORE YOU WRITE RPL.
1- ERASE BB5PLUS PHONE WITH ATTACHED ERASE FILE
2- FLASH BACK ONLY WITH UNSUPPORTED UNLOCK FIRMWARE 58XX
3- WRITE RPL
4- DONE***
AFTER ALL THIS YOUR IMEI BACK TO NORMAL
IF YOU STILL HAVE FOLLOWING MESSAGES LIKE
CONTACT SERVICE
FAIL TO READ
ETC
SO FOLLOW SOLUTION UNLOCKING LAB HERE
OR IF POSSIBLE SHAHID PLEASE UPLOAD VIDEO WITH 120 PM EDITING AND WRITING PROCESS.
DON,T FORGET TO DOWNLOAD VIDEO HERE
FOR WORKING RPL CONTACT ME BY PM.
File Type: rar ERASE BB5.rar (165 Bytes, 4151 views)
The Following 31 Users Say Thank You to UHK For This Useful Post:
Old 04-27-2009, 02:43   #2 (permalink)
Member: 517371
Sonork: 100.112658
Thanks Meter: 801
Good work Usman keep it up ....
Shahid Abbasi
UnlockingLab
The Following 2 Users Say Thank You to UnlockingLab For This Useful Post:
Old 04-27-2009, 02:47   #3 (permalink)
Member: 218086
Sonork: 0111010001011101010111010
Thanks Meter: 73
Good work uhk
tsm2318
The Following User Says Thank You to tsm2318 For This Useful Post:
Old 04-27-2009, 02:48   #4 (permalink)
Member: 656408
Sonork: 1589639
Thanks Meter: 48
n96 not imei
hello mr.. i have n96 not see the imei, the imei in the jaf is blank, i flashed my n96 with lastest firmware and not boot, flash ok, the imei no see...
i need the rpl and pm for boot this phone...my email is [email protected]
ERASE FLASH
ETC
OR IF CLICK HERE
3- WRITE RPL
4- DONE***
CONTACT SERVICE
FAIL TO READ
ETC
The Following 2 Users Say Thank You to envasis For This Useful Post:
Old 04-27-2009, 07:47   #5 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 368
help me bros.i have here 6500s 59.60 SL3 which was damaged from other shop with imei 12345.when the unit came to me its status was when turned on it just shows nokia logo then reboots then white screen.good thing they have rpl back up.i tried following guides here.
1.erase with special erase file
2.full flash with v59.60
3.write back up rpl
result phone still same status with logo then reboot but in jaf when i read info
Reading...
Failed! Aborting! IMEI
but when i tried back up rpl and pm crt it shows
Saved to C:\Program Files\ODEON\JAF\ProgData\35202702947843_CRT_backup_1111274.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
Failed! Aborting!
Failed to backup LCK...
see that imei is now fixed thru the back up rpl and not 1234 anymore but still phone cant boot properly.i guess i need the pm120 for this phone.i hope someone can share here.tia and more power.....
@UHK what do you think about the situation of my phone?hope to get some help from you.tia
The Following User Says Thank You to alfox For This Useful Post:
Old 04-27-2009, 09:47   #6 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,487
VERY FUNNY POST
Can u please explain me here .
when you erased it with 64mb and flash it..so you don't think you need to restore PM308
FAILD TO READ
doesn't mean to write only 120 PM Field and all wil be ok specialy when you erased it .
and telll me please what was the version in phone before ERASED .
what about SIMLOCK SEND. FAILED
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 04-27-2009, 11:48   #7 (permalink)
Gsm Mardan's Avatar
Member: 897494
Sonork: 100.1581481
Thanks Meter: 1,102
VERY FUNNY POST
FAILD TO READ
I m also agree with ..::Angel::..
The Following User Says Thank You to Gsm Mardan For This Useful Post:
Old 04-27-2009, 11:48   #8 (permalink)
Gsm Mardan's Avatar
Member: 897494
Sonork: 100.1581481
Thanks Meter: 1,102
VERY FUNNY POST
FAILD TO READ
Old 04-27-2009, 12:05   #9 (permalink)
babyelephantt's Avatar
Member: 240665
Thanks Meter: 85
Can you prepare a solution for SL2 too
Hello Usman,
Good solution for SL3 imei problem solutions. Can you please work and give solution for SL2 phones that the imei has got the same problem?
Thanks in advance.
The Following User Says Thank You to babyelephantt For This Useful Post:
Old 04-27-2009, 12:19   #10 (permalink)
Member: 643472
Sonork: 100.96901
Originally Posted by babyelephantt View Post
Hello Usman,
Thanks in advance.
No Solution for damage NPC, if you've backup than write it otherwise use BB5ASK2rpl from Nokia sever .
about SL3 if you downgrade it with SL2 Unprotected firmware than IMEI and Simlock will be damage, in this case you only need to flash with same version.
IMEI and SIMLOCK will be ok .
if you've sl3 phone on contact service it's damage during bad unlocking. so you need to write only pm120 filed it will become on normal state.but if u don't paly it before ..ERASE FLASH bla bla ...
More info Check Here
Nokia - SL3 Firmwares & info .
Old 04-27-2009, 17:15   #11 (permalink)
Member: 411831
Thanks Meter: 215
nice information.
keep it & help each other.
The Following User Says Thank You to msantar For This Useful Post:
Old 04-27-2009, 17:44   #12 (permalink)
UHK
UHK's Avatar
Member: 13737
Sonork: 100.100725
Thanks Meter: 191
can you read phone with an other tool and see imei status
3.write back up rpl
in your i thing you need to write MASS contenet which is LEVEL 3 can do
send back Nokia.
Originally Posted by ..::Angel::.. View Post
VERY FUNNY POST
FAILD TO READ
i thing we solving first imei from 12345 to original
offcource pm 308 is already tempered thats why you need RPL to restore
but as concern about sim lock failed so bro this is SL3 version 58.59
and there is no tool who solve sim lock problem by RPL except recent release phoniex new files
tcsclient.dll version 1.0.0.41 (Standard) for normal use
tcsclient.dll version 1.0.0.42 (Special) to be used when experiencing
problems with SIM Lock version
i hope u get the answer and if you have any solution than i appreciate please share with us
Originally Posted by msantar View Post
nice information.
The Following User Says Thank You to UHK For This Useful Post:
Old 04-27-2009, 18:03   #13 (permalink)
UHK
UHK's Avatar
Member: 13737
Sonork: 100.100725
Thanks Meter: 191
we are talking here SL3 phones with no RPL back up and same version 58.58
even flash correct version but imei is still 12345
will you able to show how you restore imei 12345 without RPL ??
and also if you could show step by step working solution 120 pm writing ?
REGDS
Old 04-27-2009, 19:46   #14 (permalink)
Member: 643472
Sonork: 100.96901
REGDS
Yes,without rpl possible to repair npc imei 12345 to original state in only SL3.but its possible when you don't play with your phone before. i mean ERASE Flash and other thing .
Suppose if you have 5310 with protected firmware v58.58 and you try to downgrade.it's become on Contact Service So you need to flash with SAME VERSION IMEI and SIMLOCK willl be fine .
but as you are saying .
So its mean you erased your phone with 64mb or any file .
So you don't neeed to erase your phone bcoz during unlocking software write the recalcuated pm120 filed but it can't write 308 it's protected .
So Simple restore pm120 with same network .
but i m not sure that pm120 will be write back on sl3 or not .bcoz it had protected firmware too.
TRY IT .
@UHK
i think we don't need to erase phone if IMEI and pm308 field are OK . Otherwise you need BB5 ASK2RPL .but rpl can't fix simlock data in Sl3 phones .
yes. phoniex released new files
check here
SL3 Firmware
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 04-27-2009, 20:01   #15 (permalink)
UHK
UHK's Avatar
Member: 13737
Sonork: 100.100725
Thanks Meter: 191
[QUOTE=UHK;4395233]*** SL3 IMEI 12345 SOLUTION WITH RPL ***
ERASE FLASH
ETC
SO DID YOU NOT READ MY POST IN START??
OR YOU UNDERTAND NOW WHAT IU WROTE BEFORE??
..::5310 imei 12345? after flashing with mxkey::.. HUM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 37 07-14-2010 14:01
5310 imei 12345? after flashing with POTATO BOX :.. mobilepoint MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-26-2010 10:21
Soon will get solution for BB5 IMEI 12345...... akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 02-04-2010 20:39
simplle solution sample for imei 12345 after unlock with UB alfox Universalbox 2 04-08-2009 04:04
Bb5 Imei 12345..... Abussabah Nokia Base Band 5 ( BB-5 ) 8 07-04-2007 07:01
Page generated in 0.51631 seconds with 9 queries
