03-24-2009, 11:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 44
Member: 162029 Status: Offline Thanks Meter: 202 | !!!TRICK to Put N82 to LOCALMODE!!! and it all failed me But the idea that phone doesn't stay in local mode due to lack of power from box so here's waht I did... I used its battery as a power source... just connect the positive and negative of battery to positive and negative of cable... In the photo attached i used lead and twisters to do it but you can modify cable (if you want to look more professional) And here is result: Code: JAF version 1.98.63 Detected PKEY: 90003BBF Card life counter: 42.44% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: D:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: D:\UFS_HWK\Products\ JAF USB LOADERS DIR: D:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: D:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v47.5 07-12-07 RM-313 (c) Nokia HW version: 4003 PCI version: RFIC version: 17141715 DSP version: mc_3131_ICPR62_2007w44 Retu version: 15 Tahvo version: 22 Production serial number: CRD477980 Product code: 0551533 Module code: Basic production code: 0549319 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358984011824656 IMEI spare to net: 3A 85 89 04 11 28 64 05 IMEI SV to net: 33 85 89 04 11 28 64 05 F3 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-313.ini Saved INI not found, loading INI list... Searching for JAF saved location of ini... Checking path: D:\UFS_HWK\Products\\ Searching for default location of ini... Checking path: \Products\\ Searching for JAF saved location of ini... Checking path: D:\UFS_HWK\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Hopefully this will help you... Last edited by alayne; 03-24-2009 at 11:38. |
The Following 8 Users Say Thank You to alayne For This Useful Post: |
03-24-2009, 12:49 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: Greenhills,Philippines
Member: 771856 Status: Offline Sonork: 100.1582636 Thanks Meter: 793 | Simple Buy GOOD Fbus cable then check if what value of resistor in bsi if the resistor is 7.5! Only can do is change it! in to 10k and 100% work's fine !!! |
The Following User Says Thank You to JaY'Treze For This Useful Post: |
03-24-2009, 18:25 | #6 (permalink) |
Freak Poster Join Date: Apr 2005 Location: INDIA Age: 43
Member: 138224 Status: Offline Thanks Meter: 56 | use only 15 k ohm risistan in cable n remove 68k phone will ready for local or test mode . |
The Following User Says Thank You to vipinverma For This Useful Post: |
01-14-2010, 11:07 | #10 (permalink) | |
No Life Poster Join Date: May 2008 Location: arth'*****
Member: 776884 Status: Offline Sonork: techno-gsm Thanks Meter: 152 | Quote:
plz show us the screenshot....thanks. | |
how to put v3 to boot mode | parinjani | Smart-Clip | 3 | 03-25-2006 12:45 |
How to put imei to pm? | yoya | Nokia Hardware & Hardware Repair | 1 | 06-14-2005 09:01 |
Help me to put Russian to GD92C | sergeihar | Panasonic | 3 | 03-28-2003 14:59 |
