11-05-2006, 23:54 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 383519 Status: Offline Thanks Meter: 0 | nokia bb5 format I tried to use the phoenix 2006 for mig bb5, but some thing goes wrong and then I formated my nokia bb5. Now i can not use it, only booting and there is no menu. please I need help if some body have a solution to return mig nokia to work again. Thank in advance. |
11-06-2006, 00:20 | #2 (permalink) |
Freak Poster Join Date: May 2006 Location: Lomnica, Serbia Age: 43
Member: 275559 Status: Offline Thanks Meter: 6 | No solution for home users,unless you have series 40 Nokia!? Since you used Phoenix then you must not have a flash box,so you need to take your Nokia to the nearest service which has the apropriate box to revive your BB5 Nokia or,if your phone is series 40 (you should have said which phone you flashed) check the threads about reviving dead BB5 Nokias in this room of the forum!! Pozdrav |
11-06-2006, 02:44 | #4 (permalink) |
Member: 275559 Status: Offline Thanks Meter: 6 | You might be able to revive it,check the threads about reviving dead BB5 Nokias,or download BB5 Reaper v3... and you will have animated guide how to try to revive it! Pozdrav |
11-06-2006, 17:28 | #7 (permalink) |
Member: 275559 Status: Offline Thanks Meter: 6 | They just need to read the threads I mentioned (My success in reviving dead 6280 or Dead BB5 flashing or... there are realy a lot of threads) and I'm not about to search instead of you and copy/paste to you what people sugest how to revive it,GO AND READ!! Pozdrav |
pro flash nokia 6230i Formating MM...Format failed | bassemzini | Nokia Hardware & Hardware Repair | 4 | 05-13-2011 00:04 |
Bb5 Format Solution With Keys??????? | malikkk | Nokia Base Band 5 ( BB-5 ) | 29 | 04-20-2007 04:06 |
BB5 format user area (format C) | mail0 | HWK | 4 | 03-23-2007 14:22 |
any converter for noking format (*.txt) to nokia bin format (*.re) ringtones??? | josaix | Nokia Multimedia | 9 | 05-04-2002 16:10 |
