10-02-2012, 19:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: algeria
Member: 1503017 Status: Offline Thanks Meter: 447 | HOT - Phoenix Service Software 2012.36.001.48629 CRACKED LAST VERSION OR Phoenix_Service_Software_2012.36.001.48629_Cracked .rar OR Phoenix_Service_Software_2012.36.001.48629__ed.rar - 107.0 MB Code: Main component versions in the release: • Product API 2012.31.2 • Nokia Connectivity Cable USB Driver Version 7.1.78.0 • Flash Update Package 2012.30.1 • FUSE Connection Manager v 2012.27.4 MAIN CHANGES & ERROR CORRECTIONS FROM PREVIOUS VERSION 2012.24.0.48366 Error Corrections & changes: New products: RM-908, RM-909, RM-872, RM-873, RM-874, RM-907 Please note: IMPORTANT! Phoenix installation requires a network connection if DOT.NET framework 4.0 is not installed on PC (.NET framework is downloaded from web during phoenix installation). New common data package location in use. Please see document SR1315 in KICS Information Center for further information. All Nokia Service Software Applications will use following location for product specific data: - Windows XP: C:\Documents and Settings\All Users\Application Data\Nokia\Packages - Windows 7: C:\Program Data\Nokia\Packages Please see articles SR1774 for more information on the use of Nokia Data Package manager – tool, and article SR1854 for more information on the Nokia Service Application Manager Tool. During installation, Data Packages should be installed in these directories, if they install to any other location by default. Target folder for local data packages can be changed in the installation wizard manually. This version contains the latest Tucson components. Therefore it is not necessary to use Tucson Add-On Installation Packages. Before you start Phoenix or Care Suite installation to Windows 7 the User Account Control (UAC) should be turned off from Windows Control Panel settings. For more information concerning new options in “Firmware Update” – menu and their use, Please see documents SR1313 and SR1659 in KICS Information Center. Tucson operations combined with “flash” – option are now handled in the same way as “refurbishment”, which requires Mass Memory Content File to be available. Use of Flash option simultaneously with product code change for USB Only phones is restricted. It is recommended to flash phone separately with Firmware Update. Please refer to product specific instructions. Connection media to FLS-5 must be configured to be “USB_FBUS”, after FLS-4 support has been removed FBUS does not work anymore with FLS-5 KNOWN ERRORS & LIMITATIONS Energy Management Calibration should not be performed for products using the “Quantum” engine (RM-689, RM-702, RM-704 and other product using the same engine) • N9- RM-696 Product Code change still unreliable • Nokia 500 RM-750 Refurbish may occasionally fail. • Product code change is not working with RM-838, RM-852, RM-843. Please use Product identity tool (SR2872) • FLS-5 drivers do not support 64 bit OS, so phones using FLS-5 /USB_FBUS connection can not be serviced in 64 bit operating systems • Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept. • Flashing with setup FLS-5, SS-46 and product specific adapter is not supported anymore. FLS-5 can be used with other product specific cables and adapters, but not with SS-46 Interface Adapter. • If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong. This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8. • FPS-21 flashing for RX-51 works only with TCPIP connection. FPS-21 prommer with new HW version 11 has been released to correct this. Sales pack code is 0089J83 , old HW version is not delivered anymore • Please refer to product specific documents and instructions concerning the limitations of the RX-51 product • When version 2010_12_8_42304 or newer with FUSE connection manager is installed on top of older Phoenix versions, there may be an additional delay of several minutes when you start Phoenix for the first time. Please wait patiently; Phoenix will start after configuration is finished. • When using Data Package download functions with online connection, download times may occasionally be long. This is not caused by Phoenix (or Care Suite). The download speed from online servers is occasionally is known to be slow, depending on how data is buffered on caching servers. • After you close Phoenix, it may not restart. To rectify this: - Use Windows Task Manager to manually shut down phoenix.exe and FuseService.exe processes, or optionally restart your PC • It is not possible to program Mass Media Content file to some devices over direct USB cable connection, due to the large size of the file. For these models a feature called “Media Check” has been implemented. When this type of product is connected to service software / PC via direct USB cable the refurbishment option will be disabled. Please use a flash prommer. Affected products using Media Check are: RM-122, RM-175, RM-176, RM-186, RM-246, RM-247, RM-296, RM-297, RM-320, RM-462, RM-472, RM-484, RM-505, RM-555, RM-559 • To be able to use the help files in Windows 7 you need to install Windows Help program (WinHlp32.exe) for Windows 7. Ways to locate WinHlp32.exe: - Start Phoenix with online connection to Internet, select “Help” and “Phoenix help”. Click the “Microsoft Help and Support” website link. Download WinHlp32 and install it.- Go to Microsoft Home Page | Devices and Services. Type “WinHlp32″ to “Search Microsoft.com” – field. Locate Windows Help program (WinHlp32.exe) for Windows 7 and install it • When using flash prommers, only one connection type to one prommer is allowed. Please use either NFPD USB or NFPD TCPIP connection to one prommer, not both connections to same prommer Supported operating systems and user rights • Windows XP Service Pack 1 or higher • When installing Phoenix into Win XP you must have local admin rights. • When using in Win XP, user must have power user rights. • Windows 7 32 Bit version • Windows 7 64 Bit version (Please note that FLS-5 drivers do not support Win 7 64 bit OS, therefore FLS-5 can not be used in this operating system) |
The Following 3 Users Say Thank You to aziahmed For This Useful Post: |
10-03-2012, 11:24 | #3 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | 5220 rm-411 Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 307008 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Asic CMT: Start programming 35212 KB... Asic CMT: Erasing rm411__07.23.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing rm411__07.23.ppm_ma Asic CMT: Erasing area 1... Asic CMT: Erasing rm411__07.23.image_ma_na_blue Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Programming rm411__07.23.mcusw Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming rm411__07.23.ppm_ma Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming rm411__07.23.image_ma_na_blue Asic CMT: Programming 76% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Reading Dynamic Camera Configuration ID 1 Updating configuration of camera with ID 1 Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NIMMIIIIRRFF094B2F01 was found. Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: EmergencyNumbers, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: DateTimeSettings, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: Certificates, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 5 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
The Following User Says Thank You to aziahmed For This Useful Post: |
10-03-2012, 14:46 | #4 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | N97 RM-555 Code: Flashing started Creating product data items list Product data items list created Backing up data items Backing up data items Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, skipping backup Backup/restore result: 0 out of 1 items were not backed up Backup complete Flashing phone Initializing Verifying communication to device... Scanning image files... Loading secondary boot code: 15232 bytes Secondary boot loaded Loading update server code: 2939087 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Asic CMT: Start programming 139394 KB... Asic CMT: Partitioning RM-555_30.0.004_prd.core.C00 Asic CMT: Partitioning area 1... Asic CMT: Erasing RM-555_30.0.004_prd.core.C00 Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing partition 0x0000000A... Asic CMT: Erasing RM-555_30.0.004_prd.rofs2.V45 Asic CMT: Erasing area 1... Asic CMT: Erasing RM-555_30.0.004_C01_prd.rofs3.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Asic CMT: Erasing area 1... Asic CMT: Programming RM-555_30.0.004_prd.core.C00 Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming 76% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming RM-555_30.0.004_prd.rofs2.V45 Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming RM-555_30.0.004_C01_prd.rofs3.fpsx Asic CMT: Programming RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Restoring user data Restoring user data Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 1 items were not backed up Data restoring completed Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-06-2012, 11:49 | #5 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | 6303 RM-443 . Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 430464 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Asic CMT: Start programming 42221 KB... Asic CMT: Erasing rm443__10.12.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing area 7... Asic CMT: Erasing area 8... Asic CMT: Erasing rm443__10.12.ppm_c Asic CMT: Erasing area 1... Asic CMT: Erasing rm443__10.12.image_c_fr_matt_black Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Programming rm443__10.12.mcusw Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming rm443__10.12.ppm_c Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming rm443__10.12.image_c_fr_matt_black Asic CMT: Programming 76% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: EmergencyNumbers, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-14-2012, 09:08 | #6 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | N97mini RM-555 Code: Flashing started Creating product data items list Product data items list created Backing up data items Backing up data items Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, skipping backup Backup/restore result: 0 out of 1 items were not backed up Backup complete Flashing phone Initializing Verifying communication to device... Scanning image files... Loading secondary boot code: 15232 bytes Secondary boot loaded Loading update server code: 2939087 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Asic CMT: Start programming 139394 KB... Asic CMT: Partitioning RM-555_30.0.004_prd.core.C00 Asic CMT: Partitioning area 1... Asic CMT: Erasing RM-555_30.0.004_prd.core.C00 Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing partition 0x0000000A... Asic CMT: Erasing RM-555_30.0.004_prd.rofs2.V45 Asic CMT: Erasing area 1... Asic CMT: Erasing RM-555_30.0.004_C01_prd.rofs3.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Asic CMT: Erasing area 1... Asic CMT: Programming RM-555_30.0.004_prd.core.C00 Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming 76% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming RM-555_30.0.004_prd.rofs2.V45 Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming RM-555_30.0.004_C01_prd.rofs3.fpsx Asic CMT: Programming RM555_APE_ONLY_ENO_09w40_v0.032.fpsx Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Restoring user data Restoring user data Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 1 items were not backed up Data restoring completed Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-14-2012, 14:15 | #7 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | 6300 RM-217 Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 14528 bytes Secondary boot loaded Loading update server code: 248320 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Using 128k file from rm217__07.30.image_ora_pl_red_128... Asic CMT: Start programming 23669 KB... Asic CMT: Erasing rm217__07.30.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing area 7... Asic CMT: Erasing area 8... Asic CMT: Erasing area 9... Asic CMT: Erasing rm217__07.30.ppm_b Asic CMT: Erasing area 1... Asic CMT: Erasing rm217__07.30.image_ora_pl_red_128 Asic CMT: Erasing area 1... Asic CMT: Programming rm217__07.30.mcusw Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming rm217__07.30.ppm_b Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming 76% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming rm217__07.30.image_ora_pl_red_128 Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: VoiceMailBoxNumbers, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: Certificates, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: EmergencyNumbers, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 4 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-16-2012, 09:05 | #8 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | 2690 rm-635 Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 300160 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Asic CMT: Start programming 28207 KB... Asic CMT: Erasing rm635__10.10.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing rm635__10.10.ppm_m_h Asic CMT: Erasing area 1... Asic CMT: Erasing rm635__10.10_005.image_m_h_vodacom_za_95783 Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Programming rm635__10.10.mcusw Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming rm635__10.10.ppm_m_h Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming 76% Asic CMT: Programming rm635__10.10_005.image_m_h_vodacom_za_95783 Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Reading Dynamic Camera Configuration ID 1 Updating configuration of camera with ID 1 Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NI00IIIIRR030C213402 was found. Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: Certificates, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-25-2012, 11:18 | #9 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | E65 RM-208 Code: Flashing started Creating product data items list Product data items list created Backing up data items Backing up data items Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.0" set to defaults, skipping backup Backup/restore result: 0 out of 1 items were not backed up Backup complete Flashing phone Initializing Verifying communication to device... Getting product info... Scanning image files... No file data found. Unable to find flash descriptors! AdlServer: Flashing Update Server Data: 46272 bytes AdlServer: Flashing CMT UPS data 4% AdlServer: Flashing CMT UPS data 12% AdlServer: Flashing CMT UPS data 21% AdlServer: Flashing CMT UPS data 33% AdlServer: Flashing CMT UPS data 41% AdlServer: Flashing CMT UPS data 54% AdlServer: Flashing CMT UPS data 62% AdlServer: Flashing CMT UPS data 71% AdlServer: Flashing CMT UPS data 83% AdlServer: Flashing CMT UPS data 91% AdlServer: Flashing CMT UPS data 100% AdlServer: UPS data loaded AdlServer: Update Server code succesfully sent to phone AdlServer: Flashing Update Server Data: 93696 bytes AdlServer: Flashing APE UPS data 2% AdlServer: Flashing APE UPS data 10% AdlServer: Flashing APE UPS data 20% AdlServer: Flashing APE UPS data 31% AdlServer: Flashing APE UPS data 41% AdlServer: Flashing APE UPS data 51% AdlServer: Flashing APE UPS data 61% AdlServer: Flashing APE UPS data 72% AdlServer: Flashing APE UPS data 82% AdlServer: Flashing APE UPS data 90% AdlServer: Flashing APE UPS data 100% AdlServer: UPS data loaded AdlServer: Update Server code succesfully sent to phone Asic CMT: Verifying communication to device... Asic APE: Verifying communication to device... Asic CMT: Verifying communication to device... Asic APE: Verifying communication to device... Flashing AdlLdrSafe device... Asic CMT: Start programming 4682 KB... Asic CMT: Erasing rm208_m128_h20_ka_prod_406337400_c00_combined.bin Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Partitioning rm208_m128_h20_ka_prod_406337400_c00_combined.bin Asic CMT: Programming rm208_m128_h20_ka_prod_406337400_c00_combined.bin Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 11% Asic CMT: Programming 13% Asic CMT: Programming 15% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 47% Asic CMT: Programming 49% Asic CMT: Programming 51% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 73% Asic CMT: Programming 75% Asic CMT: Programming 77% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 99% Asic CMT: Programming 100% Asic APE: Start programming 53269 KB... Asic APE: Erasing rm208_m128_h20_ka_prod_406337400_c00_combined.bin Asic APE: Erasing area 1... Asic APE: Erasing area 2... Asic APE: Erasing area 3... Asic APE: Erasing rm208_m128_h20_ka_prod_406337400_v01_variant.bin Asic APE: Erasing area 1... Asic APE: Partitioning rm208_m128_h20_ka_prod_406337400_c00_combined.bin Asic APE: Partitioning area 1... Asic APE: Programming rm208_m128_h20_ka_prod_406337400_c00_combined.bin Asic APE: Programming 0% Asic APE: Programming 2% Asic APE: Programming 4% Asic APE: Programming 6% Asic APE: Programming 8% Asic APE: Programming 10% Asic APE: Programming 12% Asic APE: Programming 14% Asic APE: Programming 16% Asic APE: Programming 18% Asic APE: Programming 20% Asic APE: Programming 22% Asic APE: Programming 24% Asic APE: Programming 26% Asic APE: Programming 28% Asic APE: Programming 30% Asic APE: Programming 32% Asic APE: Programming 34% Asic APE: Programming 36% Asic APE: Programming 38% Asic APE: Programming 40% Asic APE: Programming 42% Asic APE: Programming 44% Asic APE: Programming 46% Asic APE: Programming 48% Asic APE: Programming 50% Asic APE: Programming 52% Asic APE: Programming 54% Asic APE: Programming 56% Asic APE: Programming 58% Asic APE: Programming 60% Asic APE: Programming 62% Asic APE: Programming 64% Asic APE: Programming 66% Asic APE: Programming 68% Asic APE: Programming 70% Asic APE: Partitioning rm208_m128_h20_ka_prod_406337400_v01_variant.bin Asic APE: Partitioning area 1... Asic APE: Programming rm208_m128_h20_ka_prod_406337400_v01_variant.bin Asic APE: Programming 72% Asic APE: Programming 74% Asic APE: Programming 76% Asic APE: Programming 78% Asic APE: Programming 80% Asic APE: Programming 82% Asic APE: Programming 84% Asic APE: Programming 86% Asic APE: Programming 88% Asic APE: Programming 90% Asic APE: Programming 92% Asic APE: Programming 94% Asic APE: Programming 96% Asic APE: Programming 98% Asic APE: Programming rm208_cp_3.0.fpsx Asic APE: Programming 100% Finished Flashing Rebooting to Normal Mode... Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Started product mode change Product mode change complete Doing factorysets Factorysets complete Restoring user data Restoring user data Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.0" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 1 items were not backed up Data restoring completed Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-25-2012, 15:24 | #11 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | C1 RM-607 Code: Flashing started Creating product data items list Product data items list created Backing up data items Backing up data items Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, skipping backup DataItem "ISSVariantActivator" version "1.0" set to defaults, skipping backup Starting backup/restore sub-procedure: mode change post delay mode change post delay mode change post delay Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: File2Files, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Backup complete Flashing phone Initializing Download files list initiated Verifying communication to device... Waiting for USB device... Booting... Sending EBL loader... Sending EBL... Boot successful Downloading file: rm607__06.07.mcusw Erasing 131070 bytes... Total progress: 8% Sending data... Total progress: 16% Erasing 262142 bytes... Total progress: 20% Total progress: 24% Sending data... Total progress: 32% Erasing 131070 bytes... Total progress: 40% Sending data... Total progress: 48% Erasing 1048574 bytes... Total progress: 50% Total progress: 52% Total progress: 54% Sending data... Total progress: 64% Erasing 24641534 bytes... Total progress: 66% Total progress: 68% Total progress: 70% Sending data... Total progress: 72% Total progress: 74% Total progress: 76% Total progress: 78% Downloading file: rm607__06.07.ppm_ob Erasing 3661498 bytes... Total progress: 80% Total progress: 82% Total progress: 85% Total progress: 87% Total progress: 89% Sending data... Total progress: 92% Total progress: 95% Total progress: 98% Total progress: 100% Resetting device Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Reading Dynamic Camera Configuration ID 1 Updating configuration of camera with ID 1 Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NI00CS00000401022E05 was found. Restoring user data Restoring user data Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 DataItem "ISSVariantActivator" version "1.0" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: File2Files, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Data restoring completed Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
10-29-2012, 08:55 | #12 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | x2 RM-618 Code:
10-31-2012, 10:21 | #13 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | RM-348 N79 Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 15232 bytes Secondary boot loaded Loading update server code: 2506515 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Asic CMT: Start programming 134624 KB... Asic CMT: Partitioning RM-348_32.001_prd.core.fpsx Asic CMT: Partitioning area 1... Asic CMT: Erasing RM-348_32.001_prd.core.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing partition 0x0000000A... Asic CMT: Erasing RM-348_32.001_008_prd.language.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing RM-348_32.001_53.1_prd.customer.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing RM-348_32.001_003_000_U001.uda.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing vivien_eno_imaker_ape_only.fpsx Asic CMT: Erasing area 1... Asic CMT: Programming RM-348_32.001_prd.core.fpsx Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming 76% Asic CMT: Programming RM-348_32.001_008_prd.language.fpsx Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming RM-348_32.001_53.1_prd.customer.fpsx Asic CMT: Programming RM-348_32.001_003_000_U001.uda.fpsx Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming 94% Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming vivien_eno_imaker_ape_only.fpsx Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 1 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. |
01-03-2013, 08:35 | #14 (permalink) |
Member: 1503017 Status: Offline Thanks Meter: 447 | C2 RM-704 Code: Flashing started Creating product data items list Product data items list created Backing up data items Backing up data items Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, skipping backup DataItem "ISSVariantActivator" version "1.0" set to defaults, skipping backup Starting backup/restore sub-procedure: mode change post delay mode change post delay mode change post delay Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: File2Files, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Backup complete Flashing phone Initializing Download files list initiated Verifying communication to device... Waiting for USB device... Booting... Sending EBL loader... Sending EBL... Boot successful Downloading file: rm704__03.99.mcusw Erasing 131070 bytes... Total progress: 8% Sending data... Total progress: 17% Erasing 131070 bytes... Total progress: 26% Sending data... Total progress: 35% Erasing 1048574 bytes... Total progress: 37% Total progress: 40% Total progress: 42% Total progress: 44% Sending data... Total progress: 53% Erasing 25952254 bytes... Total progress: 55% Total progress: 57% Total progress: 59% Total progress: 61% Sending data... Total progress: 63% Total progress: 65% Total progress: 67% Total progress: 70% Erasing 262142 bytes... Total progress: 75% Total progress: 80% Downloading file: rm704__03.99.ppm_m_a Erasing 3458874 bytes... Total progress: 82% Total progress: 84% Total progress: 86% Total progress: 89% Sending data... Total progress: 93% Total progress: 96% Total progress: 99% Total progress: 100% Resetting device Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Reading Dynamic Camera Configuration ID 1 Updating configuration of camera with ID 1 Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string NI00CS0000040C213402 was found. Restoring user data Restoring user data Getting Data Package Reading product state Initializing datafile DataItem "ProductProfile" version "1.1" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 DataItem "ISSVariantActivator" version "1.0" set to defaults, restoring from default datafile Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: File2Files, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Data restoring completed Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded.. |
01-09-2013, 20:12 | #15 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1861617 Status: Offline Thanks Meter: 1 | Phonx good but not work try and read the phones info i get the following msg Error loading component HRESULT 0x80040154 (-2147221164) This means: Class not registered i do not know what this means but i think ill start all over now with the process previousely described in this thread. if you have any suggestions about this new error msg or any info at all that you think might help me, please do, help me that is. also when i installed the phoenix software this last time i did not install the cable drivers. |
