10-06-2010, 08:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | x3 sim lock valid,superdonge invalid solution Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm540__04.11.mcusw as MCU [BB5,XSR 1.6] size: 25.92 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3B53AB5B RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1EB00016A60F004916907A849A6F670A0F27E192 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT update server data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update server code loaded. [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3B53AB5B [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written. Programming completed in 37.656 s Processing file: rm540__04.11.ppm_i as PPM [BB5,XSR 1.6] size: 6.53 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 9.281 s Processing file: rm540__04.11.image_i_0582086_001 as CNT [BB5,XSR 1.6] size: 13.30 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 18.687 s [ADL] Restarting phone ... [ADL] Polling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Polling for ADL device [ADL] Device found: nmwcdc\Nokia X3 USB Generic, ID: 14C4BC9F [ADL] Verifying communication to device OK. Flashing completed in 3 min 49.218 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 04.11 09-12-09 RM-540 (c) Nokia Imei plain: 35340104054900-1 Product Code: 0584187 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353401040549001 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 3 min 53.828 s Nokia USB ROM detached. |
The Following User Says Thank You to tonywireless For This Useful Post: |
10-06-2010, 10:27 | #2 (permalink) | |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Quote:
repair sd free by mxkey.thanksssssssssssssss | |
The Following 2 Users Say Thank You to [email protected] For This Useful Post: |
10-06-2010, 23:14 | #3 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | help i can flash this phone on usb but i have tried every thing possible to make the phone check on f-bus it refuses to check,i am using ufc v1 cable 3 resistor value 7.5 and funny enough i have used this same ufc to remove security code from another x3 some weeks back here is post http://forum.gsmhosting.com/vbb/f299...5/#post6347890 i have confirmed that the ufc and no 3 cable are working fine by testing on 5130 which uses cable no.3 too it worked fine so pls help me can i repair super dongle without f-bus cable.or how can i make this phone check cos i have cleaned the cable and battery contact with spirit.i am waiting for quick reply pls |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
