Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
05-06-2002, 03:47 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Find any unlocked R250 and clone it using Saras Tool 1.7. Also, restoring calibration values would be a good idea. Flashes from 888 or 868 are not suitable for R250 because of their lacking support for loudspeaker. |
05-06-2002, 08:52 | #3 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | @LEAD Remember i asked you one time about this fuc*ing speaker??? You said to clone it......well i did it->then TAMPERED!!!!!!!!!! I couldnt get it to work again,only with flashing again with 888 flash.......when i put r250 flash and eeprom.....again TAMPERED!!!!!!!!!! I tried all possible solutions....... Then i sent it to ericsson service center......you know what they told me???? IMPOSSIBLE TO REPAIR IT BY ERICCSON SERVICE CENTER EXCEPT IN BELGIUM????????????? Best regards by ABE |
05-06-2002, 12:07 | #4 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Tallinn
Member: 8496 Status: Offline Thanks Meter: 1 | R250 speaker problem Maybe it would be a good idea to return the phone to working condition using 888 flash and take it to ericsson service centre for software update. That should work. I will do it today. Andri |
05-06-2002, 15:38 | #5 (permalink) | ||
No Life Poster Join Date: Jun 2000 Location: Germany Age: 49
Member: 1647 Status: Offline Thanks Meter: 4 | Quote:
I don't know what you have done wrong, but the solution laed has given is the only posibility! I have found out the same: You will get TAMPERED everytime use use non suitable flash EEPROM and IMEI! R250s PRO only works with EEPROM and flash of the same mobile. You can't change the IMEI to original IMEI of the mobile you want to unlock. You MUST use the IMEI of the mobile flash and EEPROM are taken from!! This works!!!!!!!! But You have 100% clone incl. IMEI! Quote:
Longtime ago I had the problem with a R250s which has been unlocked by EEPROM. I don't know hiw they made it. But I wanted to get a SW update at SP and EMMA killed my mobile! Only solution is the clone-procedure!! | ||
05-07-2002, 16:00 | #6 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | For unlocking R250s via EEPROM read this post: http://forum.gsmhosting.com/vbb/show...threadid=37536 |
<< E900 network problem after imei change solution >> | Bohosh | SWIFT Platform | 10 | 10-12-2009 10:46 |
D900 network problem after imei change?? | recepoz | UST Pro II | 3 | 10-03-2006 22:46 |
k608i problem after imei change | speck | SonyEricsson (USB-Smart) | 4 | 07-09-2006 16:29 |
P910i problem After imei change | medie | Universalbox | 1 | 05-25-2006 13:38 |
sOLUTION fOR T100 SPEAKER PROBLEM | gmps2003 | Sony Ericsson Hardware Repair | 3 | 06-09-2004 10:25 |
