Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
12-06-2002, 08:37 | #1 (permalink) |
Junior Member Join Date: Dec 2002
Member: 18500 Status: Offline Thanks Meter: 0 | Ericsson T28 "dead" after flashed eeprom [email protected] |
12-07-2002, 03:30 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | To press No u must do it when mobile is OFF...........it MUST WORK WHEN PHONE IS OFF..........that means that it must WORK WHEN IS DEAD ALSO::::.............. Just try it |
12-07-2002, 17:29 | #5 (permalink) |
Member: 18500 Status: Offline Thanks Meter: 0 | i use ATR Service 5.3 to write/flash and program Doesn't work anymore it want me too press "NO" button and don't feel it when i do that,(it works before phone get dead) i think u most have a working phone who can switch on/off, program doesn't work if u have empty battery, so i need a flash/eeprom program who don't need power on phone, does Univesal SP Unlocker works? |
02-25-2003, 03:24 | #6 (permalink) |
Junior Member Join Date: Feb 2003 Location: Lisbon - Portugal
Member: 20890 Status: Offline Thanks Meter: 0 | Maybe im answering you a bit late.. i dont know if it still helps you.. IŽll say here some things that might help for your problem: Uploading EEPROM into an Ericsson phone doesnŽt interfere at all with its software.. unless during the uploading process for some reason you flashed the flash area (software area). Unless this happened you have only two other reasons for the phone become dead: An hardware problem.. or Some data in EEPROM that makes phone not to start. In this case the phone still starts even you dont see anithyng at all on screen. I believe none of this two situations happened with your phone.. it is more probable that your flash/software memory has been damaged. Even so, the phone should start upon ON pressing. If the phone is dead, it is probable that you dont know its batery state.. it is probable that it doesnŽt charge the battery at all. Connect 5V to data cable linking pin 10 to GND and 11 to +5V (from left to right) while you make another try. Dont forget to disconect power and battery between each try, because the phone might be in a state that wont accept boot sequence anymore. Hope you can do it. |
03-02-2003, 09:16 | #7 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Europe Age: 48
Member: 14037 Status: Offline Thanks Meter: 1 | m in the same situaiton now . the phone can not conect when press No ,but discontect bat ,conect cable ,press on sw any function that t ask u to power on phone ,now put charged batarey and ts conect or press no and put batarey to phone .must conect m tryng all eproms now in net mght be all not work ? |
03-03-2003, 15:58 | #8 (permalink) |
Member: 20890 Status: Offline Thanks Meter: 0 | Sorry Dixon, iŽm not sure i understood your message, anyway, thinking about T28 phones that do not start even just for flash: There area some hardware problems that may be responsable for it, one of them and the most usual is the PA IC. Please visit this italian site, is has some info that might be usefull, hope you understand a bit of italian. http://www.timewalker.it/blasfemo/Faq/FaqT28s.asp[URL=http://www.timewalker.it/blasfemo/Faq/FaqT28s.asp] If you want i may look for Ericsson Service manual and send you the PDF files concerning to hardware faults |
03-25-2003, 11:56 | #9 (permalink) |
Freak Poster Join Date: Nov 2002 Location: Egypt
Member: 17675 Status: Offline Thanks Meter: 18 | Hi Try this solution connect the phone to cable without battery and open the program which you upload eeprom or flash and when the program ask to press NO button put the battery and then wait it will work and goog luck |
A55,A52,C55 dead after flashing,eeprom flashed over butcore and now do not response | svettas | E-Gold Based Phones | 10 | 02-12-2004 18:49 |
T28 problem after flashing and uploading eeprom | Newsted | Old Ericsson Phones & Sony Phones | 4 | 03-13-2003 19:23 |
HELP!! t28 dead after flashing | nawikre | Old Ericsson Phones & Sony Phones | 17 | 12-24-2001 09:38 |
Ericsson T28s 000809 (00w43) flash | m.com | Old Ericsson Phones & Sony Phones | 2 | 10-24-2001 17:26 |
Ericsson T28s 000809 (00w43) flash | m.com | Old Ericsson Phones & Sony Phones | 0 | 10-23-2001 12:51 |
