| Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2002 Location: whatever
Member: 8307 Status: Offline Thanks: 0
| I uploaded to my r320 wrong eeprom file and now<br />it is dead. But before i downloaded the original eeprom. ATR 5.3 expects the phone to work(have to press NO before uploading). How can i upload the correct eeprom back if the NO key does not respond? Thank you |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2000 Location: Germany Age: 35
Member: 1647 Status: Offline Thanks: 0
| Check battery! All Ericsson will be able to connect to prog also if there's a wrong or now EEPROM in it! If battery is okay it's a hardware failure! But it's not made by uploading wrong EEPROM! |
| | #3 (permalink) |
| No I uploded the Flash-file to the eeprom not the correct eeprom file. Now the phone doesn't work at all I have the correct eeprom file. But how i can upload it if the NO key don't respond? |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2001 Location: Bulgaria Age: 39
Member: 5579 Status: Offline Thanks: 0
| Even if you erase your flash and eeprom,phone must to connect with ATR5.3."NO" button is not soft,it hard connected button,when phone is powered off. |
| | #5 (permalink) |
| but it doesn't work with ATR or any other prog <br />like before i screwed the eeprom with flash-file.<br />It seems it doesn't send any signals to pc like<br />it sent before when phone was working. I also don't think it's a hardware problem. Can anybody help? |
| | #7 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Nov 2001 Location: Romania
Member: 7371 Status: Offline Thanks: 0
| Check if the battery is charged and/or replace it with another one (you can not charge the battery in your phone because charging is software controlled). The mobile should respond even if EEPROM and/or Flash are erased. Regards, |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2001 Location: Czech Republic
Member: 5575 Status: Offline Thanks: 0
| I have simillar problem. Try to upload eeprom via AllErTool by Jehtro. Put battery out of phone, click on write eeprom and when program say "Push NO" put battery in phone. It is same signal as press No. jsec |
| | #9 (permalink) |
| All Ericsson Tool by Jethro works for uploading flash from R320s, but not EEPROM (at least the new ones). Anyway, as j_sec wrote, always remove first the battery then put it back (reset phone) and press NO - mobile should respond if the battery and the cable are OK (and if there is no hardware problem). Regards, |
| | #10 (permalink) |
| With AllErTool Final version you can upload eeprom and flash. I tryed two days ago. Beta version can only upload eeprom. Once i bad flash R320 and ATR can not write eeprom (I press NO withou effect). With AllErTool I uploaded it. He can have the same problem. But if he has hardware problem (cable or mobille), this sollution do not work. jsec <FONT COLOR="#ffff00" SIZE="1">[ 06 January 2002 09:48: Message edited by: j_sec ]</font> |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
