Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
02-20-2003, 22:59 | #1 (permalink) |
Insane Poster Join Date: Nov 2001 Location: BG
Member: 7397 Status: Offline Thanks Meter: 0 | if there any dif. between T10 and T10s Sorry this questin may be stupid for you. I am newbie at erics. Annd if there difference between then do i need different (mbus) cable for them. I bought cable for T10 and now i am trying to unlock T10s but phone don't respond. By the way i want to back up flash and eeprom before unlocking which soft. do you recommend. Thanks. |
02-21-2003, 02:13 | #2 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | It's there a little difference between T10 & T18 You can Upgrade an T10 with T18's bin file ! It addings voice call functions and then automatical answer by flip (if you add an ils on the pcb) For making a backup of the eep and the flash, you can use JETHRO FLASHER or ALL ERICSSON by Varanius ... But just for unlock you can use ATR service by ZULEA ( 5.0 I preffer) You can also visit http://www.legag.com which is dedicated to ericsson phones . Max Note: Be carefull with your cable It might not be exactly the same pinouts with old ericssons like 788 !!! Maybe your cable is that ? |
02-22-2003, 21:27 | #3 (permalink) |
Member: 7397 Status: Offline Thanks Meter: 0 | Thanks for the reply. Yep you are right the cable is for 788 i have JETHRO FLASHER but i don't know the flash and eeprom size of t10s by the way can i modify it (cable) to work with t10s |
02-23-2003, 02:14 | #4 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | For modifying the cable you can take look on a small difference on here : You are just one pin to change of place ==> from pin 12 (5V) to 8 For the flash size , I don't know ! But you can make a read flash before while selecting the higher size and you will see the real size when the bin file is going writen on your hard drive ! But I think it's about 2 MO not 4 sure ! Good Flash Max_B P.S. DON'T FORGET TO KEEP YOUR BATTERY FULL CHARGED ! |
Is There Any Relation to Unlocking and Loss of network...please answer 911GT | harim_1981 | MT-BOX | 10 | 10-23-2007 09:49 |
Provider settings ? is there any way to save and write them ? | TRABEL | Motorola Hardware Repair | 0 | 01-03-2006 00:03 |
is there any differences between O2 and Imate JAM? | erwinsie | HTC & PDA WM( With Touchscreen) | 1 | 04-24-2005 15:19 |
Is there any solution for T65 and error 4017 ?? | artineo | Sony Ericsson | 5 | 09-15-2003 18:23 |
Communicating between pc and T10 | mag | Old Ericsson Phones & Sony Phones | 1 | 01-02-2002 19:59 |
