Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Old Ericsson Phones & Sony Phones
Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :)
Old 04-04-2010, 03:34   #1 (permalink)
Member: 216705
K618i gdfs errordon without TP(logs)
problem :
k618ii deads
the *******r said it just died;
gadget SE tool3/2 with logs else use TP
procedure :
check using SE tool3
1 identify
v0.915056/UNI
CARD SERIAL: 0011***
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000000000
PROCEDURE WAS STOPPED BY USER
Can't load ID loader !
Elapsed: 6 secs.
CFG:110000000000
ChipID:9900,EMP protocol:0301
Speed:921600
FLASH ID:897E
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35194201301379 CERT:N/A
FLASH CID:52 COLOR:RED
can't get packet start.
setGDFS_params failed
failed to setup GDFS
Elapsed: 16 secs.
CFG:000000000000
=== yap thats it GDFS error ===
problem in chinking not response in USB
thus use Rj45 cable k750
2 log in using username password (buy some logs)
(tick setting log in)
3 go to empty fill hit RECOVERY
RECOVERY MODE STARTED
Speed:921600
REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N
can't open file "frec\marikabrowncid16.bin"
Recovery failed. Phone dead.
Elapsed: 9 secs.
CFG:000000000000
Speed:921600
can't open file "frec\marikabrowncid51.bin"
Elapsed: 2 secs.
CFG:110000000000
RESET MODE STARTED
Speed:921600
RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
FLASH ID:897E
GOT SEED:1C69CC262380C65E15309449
P96 AUTH PASSED
PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
there you go reset to DEVELOPMENT STATE
4 flash GDFS i used k610 db2020
still on empty fill add file k610 gdfs
and flash
Elapsed: 6 secs.
CFG:110000000000
Speed:921600
FLASH ID:897E
FLASH CID:49 COLOR:BROWN
no ack during gdfs_readvar !
SCRC READ FAILURE
Elapsed: 15 secs.
CFG:000000000000
Speed:921600
LDR:060721 1021 DB2020_SERVICE_LOADER
FLASH ID:897E
writing "D:\setool3 files\gdfs_in_ssw_format\db2020\K610_GDFS_SSW.ssw"
CURRENT FLASH FILE CID:49
SSW uses full hash, hash len is: 640
Will flash 32 blocks...
Setting up GDFS...
OTP WRITE NOT EXECUTED
WRITING CLEAR SIMLOCK UNITS...
ALL UNLOCK/LOCK CODES SET TO "23572623"
there GDFS flashed
4 clear field andd add EROM db2020 cnv cid52 to cid 49
and i find the answer why?
the CId the celphone came from cid 52 and downgrade to cid 49 (cause by recovery)
SIGNING...
Elapsed: 51 secs.
CFG:000000000000
Speed:921600
FLASH ID:897E
writing "D:\setool3 files\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID4 9_DB2020.ssw"
SSW uses full hash, hash len is: 40
Will flash 2 blocks...
Setting up GDFS...
ALL UNLOCK/LOCK CODES SET TO "00606042"
SIGNING...
Elapsed: 13 secs.
if you put a wrong erom then you back to square 1 logs will be deducted again so be carfull
thats it all done phone alive and kicking no need to flash in some phone else if restarting flash fone with same version
*******r pay as much as P1,300 pesos philippine money
or $26
The Following 2 Users Say Thank You to joalbert_ramos For This Useful Post:
as gdfs DB2020 without tp free by cruiser Braycel Cruiser Suite 3 12-23-2008 09:42
Please add gdfs repair without tp stage .::MD_AKTER::. SETool2 1 12-11-2008 02:23
CAn 8360 have its GDFS written without test point? Burnt Cobba VygisToolbox 0 02-08-2006 14:01
Page generated in 0.32077 seconds with 11 queries
