Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
06-18-2004, 18:21 | #1 (permalink) |
Insane Poster Join Date: Sep 2003 Location: Greece Age: 68
Member: 40230 Status: Offline Thanks Meter: 0 | T68i all 4 locks closed. HELP Can someone help plz? |
06-18-2004, 18:41 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2004 Location: GERMANY Age: 42
Member: 60523 Status: Offline Thanks Meter: 9 | This function now works in any damage status of phone،¦s memory (GDFS area) for the following models: T68m, T68i, T200, T300, T310, T610, T616, T618 and P800. On many phones damaged by others free and/or cracked softwares, usualy is enough to apply function ،§Reset GDFS،¨. If after that the phone is still locked (4 locks closed and retry counters on 0), full flash the phone (AVR CPU and ARM CPU) and make operations for Change IMEI on this phone. For full flash the phone (AVR CPU and ARM CPU) follow the next rules: ،P For T68, T200, T300, T310, P800 use any REGULAR (NOT patched) flash files. ،P For T610 use the patched (modified) files for your language desired area. You can find this in New Support Area under the directory "EmptyBoard_ImeiChange" E.g. For T610 phone with EMEA1 languages pack, you have to use the file "T610_FullFlash_v5_EMEA1_R1L013.sbn". It will be better to flash Modem (ARM) file too (with same version - e.g. R1L013). For more details about change IMEI, please read previous section (How to change IMEI). If your phone was not an Empty Board phone (for Empty Board phones OTP IMEI is FFFFFFFFFFFFFFF) and you just want to keep the original phone،¦s IMEI (the one stored in OTP) you just have to mark the checkbox ،§Rebuild SP Area using OTP IMEI،¨. |
06-18-2004, 19:45 | #6 (permalink) |
Member: 60523 Status: Offline Thanks Meter: 9 | For T68, T200, T300, T310 and P800 phones, is just needed to mark the checkbox for IMEI change and enter the desired 15 digits IMEI. On T610 phones, after IMEI change, you have to flash the phone with special flash. You can find this in New Support Area under the directory "EmptyBoard_ImeiChange" E.g. For T610 EMEA1 you have to use the file "T610_FullFlash_v5_R1L013_EMEA1.sbn". It will be better to flash Modem (ARM) file too (with same version - e.g. R1L013). After phone was flashed with this file, you can change IMEI on this phone how many times you want and to any value you want. |
06-18-2004, 21:28 | #8 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | www.cellular-support.com has all that you need, and a lot more |
t68i with 4 locks closed, help | rushi | Sony Ericsson | 4 | 03-05-2004 07:27 |
t68i 4 lock closed help !!!!!!!!! | Yashaka | Sony Ericsson | 10 | 10-29-2003 08:40 |
SonyEricsson t68i 4 lock closed HELP!!!! | tiq | Sony Ericsson | 0 | 07-08-2003 10:51 |
T68i with 4 lock CLOSED ... | -=G3=- | Sony Ericsson | 3 | 06-10-2003 21:14 |
Nokia 3210 v.5.31 all 4 locks closed..please help | Salute | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-27-2001 21:28 |
