Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
04-03-2002, 09:04 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | As i had 2 pieces of R250 S PRO i tried to unlock them and here we go: 1. No soft available for theese phones,i didnt found it.. 2. Saras 1.7 detects it like 868S phone... 3. So i flashed it and it was still locked.. 4. I uploaded eeprom from 868S and flashed it with 868 flash and voila ,now phone is unlocked and working.... But... When i call someone i dont hear nothing..... Even when someone calls me back i dont hear nothing..... I didnt tested the phone if it was wroking before so i dont know if it is hardware or software problem...... Anyone has experience....??? Thanx.... |
04-03-2002, 22:12 | #3 (permalink) |
No Life Poster Join Date: Sep 1999 Location: Europe Age: 43
Member: 461 Status: Offline Thanks Meter: 2 | The Ericsson R250s PRO is rugged enough for difficult situations or industrial settings( 868 inside !). It is designed to withstand harsh treatment and is water, dust and shock resistant. A protective ePTFE membrane developed by Gore & Associates protects the internal mechanism. Its body is built around a sturdy magnesium alloy frame that has been further reinforced with a tough, rubber casing. |
04-04-2002, 01:42 | #4 (permalink) |
Junior Member Join Date: Dec 2001 Location: Netherlands
Member: 7702 Status: Offline Thanks Meter: 0 | Somebody just sended me this program for the R250pro, but i don't trust it.r250pro unlocker If the link doesn't work, just mail me and i mail the program to u. |
04-04-2002, 04:14 | #5 (permalink) |
Member: 4185 Status: Offline Thanks Meter: 3 | Jonwillow... As you say it is 868 inside..... So why i cannot hear anything now that i have flashed it with 868 software to unlcok it??? Everything else is woprking fine........ Just this problem about hearing........thats all....... I have flashed many 868 phones and all work fine...... But thjis r250 has problem now with hearing........ |
04-05-2002, 00:01 | #7 (permalink) |
Member: 7702 Status: Offline Thanks Meter: 0 | @jonwillow: Can you explain to me exactly what i need to do to remove the simlock off th R250pro? Cause i don't understand the way you did it. Thanx in advance. |
04-05-2002, 08:30 | #8 (permalink) |
Member: 4185 Status: Offline Thanks Meter: 3 | Hi again... @ Jonwillow Ihave emmashell ,emma flasher for 868 and emma.exe.... Which one to use and how to use it? I installed it but dont find it on programs...... Does it need crack? Thanx in advance........i sent you mail also........ |
04-05-2002, 18:40 | #10 (permalink) |
No Life Poster Join Date: Jun 2000 Location: Germany Age: 49
Member: 1647 Status: Offline Thanks Meter: 4 | Nice idea to flash with EMMAII ! Problem: There aren't many people who have EMMA II! Or they don't have dongle and smart card. If you upload clean EEPROM and flash it with sara's you'll get unremovable TAMPERED if you try to change IMEI! Only way I found out is to make a clone of a free R250s. But I'll try out the soft posted somewhere higher! |
04-05-2002, 19:03 | #11 (permalink) | |
Member: 1647 Status: Offline Thanks Meter: 4 | Quote:
Prog seems to be a hoax!!!!!! No reaction! It's with all selections or mobile phone types the same! Prog shows nothing at statusfield and doesn't entertestmode on mobiles............ | |
04-05-2002, 19:12 | #13 (permalink) | |
Member: 1647 Status: Offline Thanks Meter: 4 | How to do this ??? Quote:
When I clone it it works fine, BUT by changing IMEI to original it gets TAMPERED! I made a backup of EEPROM and firmware with sara's 1.7. Is there any other suitable flashreader for this kind of mobile?? Thx, TigErEntE | |
04-05-2002, 19:25 | #14 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | The phone after cloning only seems to be ok. It is uncalibrated and does not work well - it has problems when used in areas with worse gsm coverage. You may also encounter a phone that will not log to the network after cloning. That's the reason of copying the calibration data. Saras 1.7 is the only program I know for flash downloading from R250s. Last edited by Lead; 04-05-2002 at 19:30. |
04-05-2002, 19:31 | #15 (permalink) | |
Okay, but where to find these data. Which address should I copy?!? | |
Unlock R250Pro I mean | panji_millenium | Sony Ericsson | 0 | 12-24-2003 17:29 |
r250pro resetting network..?? | arema | Old Ericsson Phones & Sony Phones | 0 | 05-11-2003 14:53 |
