Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
05-13-2003, 13:47 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: home
Member: 15506 Status: Offline Thanks Meter: 3 | repair R380's work for me 100%! I get flash file on this forum for R380! 1.Use ATR 5.3 like R310! 2.Write eeprom and flash which is on the forum! 3.REPAIR IMEI and again same flash you must write(you will see message on sw) 4.That is all! The problem is ahter only flashing I get allways message (Incorect sim), I try to unlokc but no help! This is only way how you can repair this not bad phone! Good luck! |
06-06-2003, 09:33 | #2 (permalink) |
Junior Member Join Date: May 2003 Location: Romania Age: 56
Member: 29987 Status: Offline Thanks Meter: 1 | please send me flash and eeprom to repair r380. my mail address is: [email protected] thanx in advance |
01-28-2004, 03:17 | #6 (permalink) |
Insane Poster Join Date: Feb 2003 Location: B U L G A R I A Age: 44
Member: 20817 Status: Offline Thanks Meter: 0 | Man i don't know if that is the same problem but ,if you dropped it down the ground sometimes the pins that are soldered on the pcb are scrued.So you can check them out (use soldering iron or hot air ****er).If that's not the problem check If there is any RX and TX signal .Use ATR 5.3 |
01-28-2004, 11:50 | #7 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Hello, Just saw this and have the interest. I tried on about 4 occassions to flash this phone using the method said here, but each time it stops at 99% and gives me an error message. This made me stop trying to flash the phone. If any idea why, can some1 tell me ? Thanks dannyogolo |
01-30-2004, 16:46 | #8 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Never handle an R380 like R310 - you will only "tamper" it. Always use T1x selection in ATR 5.3 Memory organization:
02-04-2004, 13:20 | #9 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [winscard.SCardTransmit]
Member: 8023 Status: Offline Thanks Meter: 13 | I have 2 R380s which does not even communicate with nothing... is the touch screen (AFAIK the "No/PWR" button also belongs there) in any connection with power supply? or if it is a purely sw function, and the corresponding software is missing/damaged, what can I do about it? some autoignition or what? (I have fighter ) |
Touchscreen Bypass damaged calibration solution 100% work for me!!! | kalpeshoza | Infinity-Box | 17 | 01-06-2010 20:07 |
Support for infinity not work for me since 4 moths ago,no good solution from support | crossings | Infinity-Box | 6 | 06-11-2007 17:44 |
Victor Soft 2.3.2: This cable work? 'cos USB not work for me !!! | dannyogolo | Motorola P2k | 5 | 06-05-2003 08:16 |
Winmodo doesn't work for me!!!! | nightxyz | Panasonic | 0 | 01-04-2001 06:25 |
