Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
04-04-2010, 03:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: philippines
Member: 216705 Status: Offline Thanks Meter: 48 | K618i gdfs errordon without TP(logs) k618ii deads the *******r said it just died; gadget SE tool3/2 with logs else use TP procedure : check using SE tool3 1 identify v0.915056/UNI CARD SERIAL: 0011*** Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 6 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35194201301379 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 16 secs. CFG:000000000000 === yap thats it GDFS error === problem in chinking not response in USB thus use Rj45 cable k750 2 log in using username password (buy some logs) (tick setting log in) 3 go to empty fill hit RECOVERY RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid16.bin" Recovery failed. Phone dead. Elapsed: 9 secs. CFG:000000000000 RECOVERY MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 REC:070703 1229 NPA4_CXC1329130_DB2020_SEMC_RECOVERY_P3N can't open file "frec\marikabrowncid51.bin" Recovery failed. Phone dead. Elapsed: 2 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID:897E GOT SEED:1C69CC262380C65E15309449 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35194201301379 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE there you go reset to DEVELOPMENT STATE 4 flash GDFS i used k610 db2020 still on empty fill add file k610 gdfs and flash Elapsed: 6 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35194201301379 CERT:N/A FLASH CID:49 COLOR:BROWN PROCEDURE WAS STOPPED BY USER can't get packet start. no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 15 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35194201301379 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:897E writing "D:\setool3 files\gdfs_in_ssw_format\db2020\K610_GDFS_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "23572623" there GDFS flashed 4 clear field andd add EROM db2020 cnv cid52 to cid 49 and i find the answer why? the CId the celphone came from cid 52 and downgrade to cid 49 (cause by recovery) SIGNING... Elapsed: 51 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35194201301379 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID:897E writing "D:\setool3 files\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID4 9_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "00606042" SIGNING... Elapsed: 13 secs. if you put a wrong erom then you back to square 1 logs will be deducted again so be carfull thats it all done phone alive and kicking no need to flash in some phone else if restarting flash fone with same version *******r pay as much as P1,300 pesos philippine money or $26 |
The Following 2 Users Say Thank You to joalbert_ramos For This Useful Post: |
as gdfs DB2020 without tp free by cruiser | Braycel | Cruiser Suite | 3 | 12-23-2008 10:42 |
Please add gdfs repair without tp stage | .::MD_AKTER::. | SETool2 | 1 | 12-11-2008 03:23 |
CAn 8360 have its GDFS written without test point? | Burnt Cobba | VygisToolbox | 0 | 02-08-2006 15:01 |
