Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
04-01-2002, 19:10 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | strange T20s display any suggestions are most welcome... |
04-06-2002, 08:54 | #3 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Try writing one of the following sequences to the eeprom address 0A85 (make backup first): 00 03 01 00 28 58 02 35 02 49 02 35 41 25 03 01 00 28 49 02 5D 02 26 02 2F 56 21 00 03 01 00 28 4E 02 3F 02 3A 02 2F 32 28 03 01 00 28 4E 02 67 02 21 02 2F 46 21 02 03 01 00 28 58 02 35 02 49 02 2F 41 25 03 01 00 28 4E 02 67 02 2B 02 36 56 21 I really don't know which one will work for you... |
04-10-2002, 23:45 | #5 (permalink) |
Member: 4873 Status: Offline Thanks Meter: 5 | @LEAD: unfortunately the solution did not work.. tried the 3 modifications.. how about flashing the flash? what sw can i use for safely flashing t20? or maybe upgrading to t29? I'd like to use sw solution first before opening the phone... Thanks for the time man! Any other suggestions is very much appreciated |
04-11-2002, 00:33 | #6 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | If none of the sequences worked, then it is probably a hardware problem and therefore it cannot be solved by flashing. We may try calibrating voltages, so, at least, tell me which of these three sequences worked for you best. |
04-11-2002, 02:00 | #7 (permalink) |
Member: 4873 Status: Offline Thanks Meter: 5 | ok thanks, I'll try hw solution when i get hold of an LCD all the 3 modifications are the same man, the problem persists, when i turn ON the phone it shows display in a split second the slowly darkens and in about 5 secs it is totally dark... strange huh? |
04-11-2002, 05:45 | #9 (permalink) |
Member: 4873 Status: Offline Thanks Meter: 5 | yup, hasn't changed at all, phone still darkens the display and after 5 secs totally dark, haven't tried changing LCD yet cuz' I ain't got any best regards! |
04-16-2002, 03:45 | #10 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | I have a similar problem with T20. I have repaired a charging problem, phone works OK. I give it back to owner. On next dey he comm back with this problem....LCD is dark. Phone normal power on and LCD is dark, i can see what is on display, but is it dark. I have tryed changing LCD, dont work, contrast settings dont works too. No one have played with firmware or eeprom, but i will try to make settings as Leads wrote. Any other ideas are welcome |
05-06-2003, 16:37 | #14 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Port Harcourt, River State, Nigeria Age: 45
Member: 25150 Status: Offline Thanks Meter: 8 | guys i have a t20 with good lcd but no display, but when you take a very close look you will notice a very very faint display. someone pls help. thank, gibso |
7200 strange blank display | applio | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 01-07-2005 09:27 |
t20 display problem | VELIKI | Sony Ericsson Hardware Repair | 3 | 12-02-2002 11:46 |
T20 Display Back. | Pandemonio100 | Sony Ericsson Hardware Repair | 0 | 08-05-2002 17:56 |
Strange ARIA display problem! | chris_ua | Mitsubishi | 2 | 05-23-2002 04:16 |
ERCISSON T20 DISPLAY High Contrast | ARC | Old Ericsson Phones & Sony Phones | 0 | 10-23-2001 22:08 |
