What flash file I need to unlock T10 by Saras without upgrading to T18 What flash file I need to unlock T10 by Saras without upgrading to T18 or how can I unlock T10 without upgrading to T18? regards Tomi ------------------ [email protected] |
Try downloading the eeprom (with eeprom up/downloader by cage) and unlock the eeprom with some program (maybe like the one from terror) then upload it again... |
SSSTTTOOOPPP !!! Don't do that, only download but never upload --> phone can be dead !!! Try Saras by using txxwest.bin. This you can make with flash converter by cage. Don't press the all in one button. Make it step by step. First unlock, then Flash 1 and 2. But not Upgrade button. Unckeck InI File Setting and Check ASK IMEI if required. If you IMEI is not included in txxwest you can add/remove in cage flash converter. b.R. |
I have tried to do like that with saras but my T10 says now insert correct card eaven there no card in the gsm. I have tryed to use er2000 but just befor it goes to a flash it stops at the screen "Blank check..." The soft is 00w22 Made in Estonia. Any idea? |
Hello my friend !! First check that your accu is loaded fully up ! (((((this u make if u get message ERROR! after flashing in ER2000 !! then open look if pin 7 and 8 are closed !! On connector to phone. PIN 1 is the left if keyborad is above.))))) The use ER2000 and press FLASH without choosing a BIN File !! OKAY !! Try this three up to five times and it shall run. Blank checking means, that your phone wasn't able to erase flash because it has not enough power. If this doesn't work try to use external power (9 up to 12 V) too. Maybe transformator has enough power. |
