Old Ericsson Phones & Sony Phones ALL Ericsson OR SONY Phones are here, you Can't Find "SonyEricsson" in there. only SONY old phones or Ericsson old Phones.. do we need to say it again :) |
06-22-2000, 13:36 | #1 (permalink) |
Freak Poster Join Date: Feb 2000 Location: Slovakia Age: 53
Member: 965 Status: Offline Thanks Meter: 36 | What flash file I need to unlock T10 by Saras without upgrading to T18 regards Tomi ------------------ [email protected] |
07-01-2000, 14:30 | #3 (permalink) |
Banned Join Date: Jun 2000 Location: IN Samsung CERTS! Age: 38
Member: 1651 Status: Offline Sonork: 100.1623070 Thanks Meter: 110 | SSSTTTOOOPPP !!! Don't do that, only download but never upload --> phone can be dead !!! Try Saras by using txxwest.bin. This you can make with flash converter by cage. Don't press the all in one button. Make it step by step. First unlock, then Flash 1 and 2. But not Upgrade button. Unckeck InI File Setting and Check ASK IMEI if required. If you IMEI is not included in txxwest you can add/remove in cage flash converter. b.R. |
07-11-2000, 19:47 | #4 (permalink) |
Insane Poster Join Date: Jul 2000 Location: Osijek, Croatia
Member: 1711 Status: Offline Thanks Meter: 0 | I have tried to do like that with saras but my T10 says now insert correct card eaven there no card in the gsm. I have tryed to use er2000 but just befor it goes to a flash it stops at the screen "Blank check..." The soft is 00w22 Made in Estonia. Any idea? |
07-11-2000, 20:02 | #5 (permalink) |
Member: 1651 Status: Offline Sonork: 100.1623070 Thanks Meter: 110 | Hello my friend !! First check that your accu is loaded fully up ! (((((this u make if u get message ERROR! after flashing in ER2000 !! then open look if pin 7 and 8 are closed !! On connector to phone. PIN 1 is the left if keyborad is above.))))) The use ER2000 and press FLASH without choosing a BIN File !! OKAY !! Try this three up to five times and it shall run. Blank checking means, that your phone wasn't able to erase flash because it has not enough power. If this doesn't work try to use external power (9 up to 12 V) too. Maybe transformator has enough power. |
i need to flash a 8150,what flash-files do i need? | SicilianBoy | VygisToolbox | 6 | 03-13-2006 16:18 |
Need Flash file for T10s without upgrade to T18s | Vilsa | Old Ericsson Phones & Sony Phones | 5 | 08-19-2001 02:37 |
Need Flash file for T10s without upgrade to T18s | Vilsa | Old Ericsson Phones & Sony Phones | 0 | 08-07-2000 12:50 |
Need Flash file for T10s without upgrade to T18s | Vilsa | Old Ericsson Phones & Sony Phones | 0 | 08-07-2000 12:46 |
