Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Unlocker
Old 05-12-2005, 12:25   #1 (permalink)
fonefun's Avatar
Member: 26187
Not unlocking smart team help
i have 20 smart unlockers and i can not get 1 to unlock any fones except sendo need help
tried on V300 V500 V525 V600 E1000
updated all clips to version 2.11 and no joy unlocking anybody else had any issues
Tried all differant cables
Cables on smart clip that work aswell but not on smart unlocker
The Following User Says Thank You to fonefun For This Useful Post:
Old 05-13-2005, 21:27   #2 (permalink)
fonefun's Avatar
Member: 26187
its good to see good support
i have found the problem all the usb ports on the clip are set to far back so you dont get a usb connection
Old 05-14-2005, 03:54   #3 (permalink)
vandal's Avatar
Member: 45656
please could you explain it well i dont get you well
Old 05-14-2005, 09:14   #4 (permalink)
fonefun's Avatar
Member: 26187
where you plug the usb cable into the smartunlocker the cable will not go far enough into the usb port because how it is made
Old 05-18-2005, 05:30   #5 (permalink)
Member: 10730
Yes i tried with smart clip & smart Unlocker would not unlock e1000 phone rebooted but it still asked for sub code (0.6.1.2) even if i manually powered the phone after it goes off it made no differance
Old 05-18-2005, 09:34   #6 (permalink)
GSM_Support's Avatar
Member: 121052
Maybe you have a repair cable?
Check the pinout at http://www.smart-clip.com/pinout_p2k_to_usb.pdf, make sure you have a "Standard cable", try to unlock again. If no luck, then get back to us, specify the process, Write in details what was happening to the phone & SC.
Smart-clip team
www.smart-clip.com
www.GsmServer.com
Old 05-18-2005, 09:57   #7 (permalink)
::.::SOUFIZ GSM::.::'s Avatar
Member: 59209
i have an other pb mr sc support
e1000
bootloader 0.6.1.2
sw version
E1000-u-80.3f.
37.00.02p
smart can not unlock
e/g goes directly to red light
even if all is ok
Old 05-18-2005, 09:58   #8 (permalink)
Member: 10730
Thanks for your fast reply!!!!!
I use same cable to unlock v300,v545 ect.........
When i unlock e1000 boot version 0.1.6.2 something like that.....
Phone goes to boot mode ubs transfer ok
then phone reboots smartclip for 1 sec like turns off then back on again with both led red/green i try many other methods like to power on phone just after boot screen goes off but makes no differance still it ask for sub code.
Old 05-24-2005, 02:40   #9 (permalink)
karabey's Avatar
Member: 45183
I have sold about 15 SmartUnlockers but 1 of them will not Unlock the Phone. I tried with V525, V550 and C975 but the e/g light is red. I have to change the Clip but what should i do with this one which doenst work??
I changed also the Pinouts from the Cable like in PDF but the same problem.
Old 05-24-2005, 11:00   #10 (permalink)
Member: 121052
The broken one should be exchanged.
Smart-clip team
www.smart-clip.com
www.GsmServer.com
Old 05-24-2005, 11:17   #11 (permalink)
Member: 121052
Apparently your cable takes power from the clip & charges the phone. That's why the clip reboots. Exchange the cable or use a different power supply. Try with 12V & 500mA. But do not take any higher, you will burn the clip!
Smart-clip team
www.smart-clip.com
www.GsmServer.com
Old 05-26-2005, 03:09   #12 (permalink)
karabey's Avatar
Member: 45183
Now another Customer has bring in a SmartUnlocker back... I thought the People are playing with the Hardware of the Unlockers but my Security Label is on it... This Unlocker has also v2.11 and he can Unlock C975 Phones but not V3 Phones. When he presses with Unlock the e/g Light is going into Red with V3 Phone. I checked the cable but the same problem... What is the Problems with Smart Unlockers?? Smart Clip was working 100000000% better than Smart Unlocker
Regards
Semaf Electronics
www.semaf.at
Old 05-26-2005, 09:27   #13 (permalink)
Member: 121052
V3 is supported by Smart-Unlocker. It must be an error during the unlock process, unless you are experiencing a new version.
Smart-clip team
www.smart-clip.com
www.GsmServer.com
Old 05-26-2005, 10:45   #14 (permalink)
karabey's Avatar
Member: 45183
I know that is supported by SmartUnlocker. We unlocked the V3 with that way...
1. Switch On Phone
2. Connect Phone with SmartUnlocker
3. Press Unlock and wait the e/g light is "green"
If SmartUnlocker will not Boot so we are doing it manually.
I tried with an another SmartUnlocker and it Unlocked without any problems.. This one is not unlocking.
Old 05-26-2005, 14:21   #15 (permalink)
Member: 121052
In this case it has a technical problem & needs to be exchanged...
Smart-clip team
www.smart-clip.com
www.GsmServer.com
Smart Team,help! i can`t update my s-card! NO.7 Smart-Clip 8 12-16-2009 01:10
help help mtv3.3 not unloking smti team help plz bmm08 SMTi 0 01-23-2009 08:35
smart team help me on this issue a100 reconnection error gbada Smart-Clip 1 11-03-2005 10:39
smart team help me on this issue a100 reconnection error gbada Smart-Clip 1 11-03-2005 10:34
Page generated in 0.33559 seconds with 11 queries
