Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Unlocker
Old 09-24-2005, 06:01   #1 (permalink)
Member: 71052
Unlocker only works by RJ45 and Not by USB interface
HI ALL...
Since few days ago, my smart unlocker only unlocks those phones that can be unlocked by conecting on RJ45 (like C155, V180, C115, etc). But those ones required to be connected on USB interface (like Vxxx, C33x, C350, etc) always appears RED LED.
I'll apreciate all cooperation regarding this issue because I have not idea why this mal-function is happening.
Thanks
Old 09-24-2005, 10:20   #2 (permalink)
mobitek's Avatar
Member: 161012
Usb cable
Originally Posted by LonchoXP
HI ALL...
Thanks
Using a small clean toothbrush make sure the contacts on the phone are clean and free from dirt a lot of connection proplems are caused here. Try it and see does it work
Old 09-24-2005, 12:07   #3 (permalink)
mrfixit's Avatar
Member: 60899
I received brand new smart unlocker and it only work on rj45 never on usb, checked usb connector and is very clean. I believe the usb controler in the smart-unlocker is faulty.
Old 09-24-2005, 16:22   #4 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
freind it's problem form box , cabel is folty try contact you ressler to change cable or test by other usb cabel from other box from other freind
Old 09-24-2005, 22:25   #5 (permalink)
mrfixit's Avatar
Member: 60899
tried already other cable from smart-clip, works fine there, its problem in box not cable, thanks for your input.
Old 09-26-2005, 19:02   #6 (permalink)
Member: 71052
Is correct. Problem is box, not cable. I have about of 10-15 usb cables and error is the same with all of them.
Note: This error began when I powered the box using normal alkaline battery.
That was the mistake because, earlier, i used regulated power input from digital power system and it worked perfect.
It will be better a comment by SC-TEam regarding this issue.
Old 09-29-2005, 09:30   #7 (permalink)
GSM_Support's Avatar
Member: 121052
If the battery was not full it could cause Unlocker malfunction. We strictly recommend to use a stable power supply (9V, 450mA) in any case!..
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 09-30-2005, 04:36   #8 (permalink)
Member: 71052
Wow!!!. So, this product is a very very delicated on its powering !!!
Low voltage protections are very simple circuits that can be implemented on this boxes to protect them and avoid this problems !!!
And besides, it will be better not include battery connector becasus this box can work with it.
Old 09-30-2005, 04:38   #9 (permalink)
Member: 71052
Best Regards
Smart-clip team
So, warranty is off???
What can I do ??
Old 09-30-2005, 16:18   #10 (permalink)
Member: 121052
If the warranty is still on, contact your supplier & exchange it.
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 11-04-2005, 18:15   #11 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
noticed also after update to 2.15 usb port already not functioning......can u pls check on this smartclip team? thanks
Old 11-05-2005, 15:47   #12 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Ok, they accept,
Any home made solution for theses customers ?
Why dont the smart Clip team use a half full battery to "damage" one smart unlocker and sort the solution out for their customers
Old 11-05-2005, 19:25   #13 (permalink)
mrfixit's Avatar
Member: 60899
mine was brand new never used, i dont even have battery, use 9 volt regulated power source, same for griffin and others, and usb never worked, i believe it is not 1/2 full battery problem.
Old 11-09-2005, 16:30   #14 (permalink)
Member: 51716
Sonork: 100.1594676
why does smart clip team not release soution for this
Old 11-11-2005, 19:37   #15 (permalink)
nicacel's Avatar
Member: 111014
I alson have this problem I used 9v battery and power supply adater 9v. but still getting mal-function, just RJ45 is not working. Using USB always red light, can't unlock.
Is there a way to fix it? Because I think warranty is over from my reseller www.unlockcellular.com
BR.
Want "EARN MONEY" by uploading and not by...TuT..? emoneme1619 Nokia Multimedia 1 11-17-2008 06:12
RJ45 Port Not responding, Usb Port OK blaiseid Smart-Clip 24 12-25-2005 17:09
gd55 only working on 02 and voda t100 Panasonic 2 11-03-2003 16:59
Page generated in 0.41412 seconds with 11 queries
