Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SWAP
Old 08-06-2005, 02:12   #1 (permalink)
gambitjam's Avatar
Member: 113732
a65
When Read Info:
Displays:
Power on
Entering boot mode.
nothing moves not even 0.1%
Old 08-06-2005, 02:48   #2 (permalink)
haiminhk15_sc's Avatar
Member: 152057
Sonork: 100.1582385
All Siemens
You must be use Testpoint in order to boot phone, after you can do anything
1. Tool Crack ( Freia, SST Crack, .. ): cut TP ( A65 TP is same A60, C60 TP or MC60 TP ), Now your phone is boot OKE
2. Orginal Box ( Martech, SST, Swap ): Use TP Adapter and you can do anything ( don't need cut TP ), at Present Swap box is not Release Swap Adapter TP V2.0
Good Luck
Old 08-07-2005, 20:02   #3 (permalink)
khawar's Avatar
Member: 51218
Originally Posted by haiminhk15_sc
All Siemens
Good Luck
SWAP, pl. give help to use testpoint needle solution (if possible).so we dont have to cut the testpoint in A65.
Old 08-26-2005, 00:06   #4 (permalink)
gambitjam's Avatar
Member: 113732
SWAP,
Help with Diagram instruction of step by step TP (TestPoint) A65/SL55.
[The connection from Phone to SWAP Box & the software setting].
Old 08-26-2005, 08:16   #5 (permalink)
Member: 81703
Khawar you have a PM...Gambitjam be patient...they will do an incredible update for sure
Old 08-28-2005, 00:24   #6 (permalink)
gambitjam's Avatar
Member: 113732
Patients is a Virtue
I WILL DO THAT FOR SWAP.
Old 08-30-2005, 18:33   #7 (permalink)
kiriazy's Avatar
Member: 50456
hey to all the test point is mc60 ...the a 60 doesn't work i've tried the both
Old 09-22-2005, 02:57   #8 (permalink)
gambitjam's Avatar
Member: 113732
SWAP. I'm out of siemens customers and out of Patience.
B E T T E R D O SOMETHING FAST OR ELSE I'LL DUMP IT FOR ANOTHER BOX.
Unlock A65 solution for free! Lpapp E-Gold Based Phones 45 10-22-2005 18:37
A65 unlock gsmfreezer E-Gold Based Phones 18 01-30-2005 15:56
russian for A65 Viking E-Gold Based Phones 0 11-14-2004 14:56
Unlock A65 neumi E-Gold Based Phones 5 11-12-2004 14:03
Siemens S65/A65 semicon E-Gold Based Phones 0 07-22-2004 12:16
Page generated in 1.51942 seconds with 11 queries
