11-17-2006, 15:55 | #16 (permalink) |
Freak Poster Join Date: Dec 2005 Location: in unlocker world Age: 44
Member: 207809 Status: Offline Thanks Meter: 13 | Trying to connect Phone connected Collecting phone information.... IMEI: 3583330000xxxxx Contacting server... Connected Phone information sent Network timeout... i have some probleme can you explain or verssion not suported i test on 3 phone br fahd-gsm |
11-25-2006, 21:53 | #21 (permalink) |
Insane Poster Join Date: Feb 2005 Location: flashgsm.ro
Member: 119482 Status: Offline Thanks Meter: 4 | You can make a connector from a thin double layer cooper PCB .My USB cable works fine.I have another problem.Is there any solution for NCK blocked ? The NCK is readed but the phone didn't let you type the NCK if the NCK is blocked.... |
11-27-2006, 15:51 | #23 (permalink) |
Freak Poster Join Date: Nov 2005 Location: in the heaven
Member: 201648 Status: Offline Thanks Meter: 19 | Trying to connect Phone connected Collecting phone information.... IMEI: 3583330000xxxxx Contacting server... Connected Phone information sent Network timeout... i have some probleme can you explain or verssion not suported i test on many phones br don omar |
11-28-2006, 22:52 | #24 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | hello friends, the software work 100%. IMEI: 358333001112345 Contacting server... Connected Phone information sent . . . Unlock codes: NCK: 44773333 SPCK: 20604468 To enter unlock codes please insert a locked simcard, phone will ask you for the unlock code. disconnecting from server all it's ok. but on display is :" NCK bloqueado. Contacte con el proveedor de servicios" and i can't write the code. i let the phone to rest few hours (like as sony j70) but not result. what can i introduce the code? regards, geo |
11-28-2006, 22:56 | #25 (permalink) | |
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | Quote:
geo | |
12-04-2006, 19:47 | #26 (permalink) |
Junior Member Join Date: Sep 2006
Member: 351185 Status: Offline Sonork: 1594614 FEYDI Thanks Meter: 0 | Problemas con TSM BOX tengo una TSM box, pero no encuentro software, y que en esta box no hay pagina de soprte, necesito ayuda por favor si alguien puede ayudarme (soy de mexico) I have a TSM box, but I have some problems I cantīs uses, where is the software for this box, support etc, if some one can help me tnkīs I from mexico |
12-12-2006, 15:46 | #30 (permalink) |
Freak Poster Join Date: Nov 2006 Location: COLOMBIA
Member: 383903 Status: Offline Thanks Meter: 3 | pantech problem when i connect the phone it connectcs and everything press unlock it says ok but it does not unlock thw pantech pg3210 Start Time : 9:36:18 Power On Phone..OK. Loading Boot..OK. Reading Phone Info..OK. Flash(1) ID : 8912 Flash(1) Type : Intel 16Mb Phone Type : Pantech G-32XX Firmware Version : HNAC0109232005PG3210L ver 1.0 End time: 9:36:27 Unlocking Phone..OK. Unlocking Phone..OK. Unlocking Phone..OK. |
MY BOX DOESN`T OPEN THE Matador Engine Maintenance Tool v1.5 | der5558 | AlcaBull | 3 | 08-02-2008 09:59 |
MANUAL: Matador Engine Installation Manual | pinheadZ | TSMbox+ | 1 | 02-09-2007 09:28 |
BETA TEST: New Matador Engine drivers | pinheadZ | TSMbox+ | 2 | 02-02-2007 20:52 |
UPDATES: 2007-01-17 - Alcatel Service Software v1.0 | pinheadZ | AlcaBull | 0 | 01-17-2007 22:58 |
UPDATES: Matador Engine Grundig G600 codereader v1.0 | al0342p | TSMbox+ | 4 | 12-23-2006 15:56 |
