Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 12-18-2008, 13:24   #1 (permalink)
Member: 474696
Thanks Meter: 109
Nokia 5320D Xpress Music Unlock Done!
Nokia 5320 Unlock Done With Usb Cable Without Problem.
Here Is Logs
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.42, and up to date.
Detecting BB5 USB device...
Reading Info...
Soft Version: V 08w17.07 Date: 10-06-08 Type: RM-409 (5320D-1 XPRESS MUSIC) Pack: (c) Nokia
Product code: 0569056
Original IMEI: ******************
Production serial: KCU003142
HW Version: 0210
DSP Version: ICPR71_08w21
LCD Version:
APE ADSP Version: 256
SIMLock service: SIMLOCK SERVER [01000407031E]
Profile bits: 0000000000000000
Simlock config: 2440700000000000
Invalid codes entered: 0 / 0
Block: 1; Lock: 1; State: Closed; Data: 26806F
Block: 2; Lock: 1; State: Closed; Data: 26806F
Security code: 12345
You should install the following application to the phone: s60_3_1_app_trk_2_8_6.sisx, or s60_3_1_app_trk_2_8_9.sisx
from path C:\Uni\Files\Nokia\BB5\ using Nokia PCSuite.
After installing please start the TRK application, and set the Connection to USB in the Options/Settings menu
and connect it to your computer by selecting the Options/Connect menu
Uploading application...
Application installed, please press on phone "Options" => "Hello"
Calculating code...
Connecting to server: US2
Credits: ****
Credits Left: ****
NCK Code: #pw+077115097513709+7#
Unlocking phone...
Unlock done
Reading Info...
HW Version: 0210
LCD Version:
All locks are open.
Done
Old 12-18-2008, 13:57   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Congrats Shahzad !!!!!!!
best of luck !!
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 12-18-2008, 15:17   #3 (permalink)
Member: 87357
Thanks Meter: 9,457
Keep it up , thanks for sharing
The Following User Says Thank You to MobilesDoctor For This Useful Post:
Old 12-28-2008, 01:31   #4 (permalink)
Member: 933278
Here Is Logs
Reading Info...
HW Version: 0210
LCD Version:
Calculating code...
Credits: ****
Credits Left: ****
Unlocking phone...
Unlock done
Reading Info...
HW Version: 0210
LCD Version:
All locks are open.
Done
with wath program you make the phone to unlock?
bacause i have 5320XM too and its locked to a portuguese network
thanks
Old 12-28-2008, 03:27   #5 (permalink)
delax2006's Avatar
Member: 305365
Thanks Meter: 90
we are in UB section....
Unfortunately, service is offline for SL2 S60 unlocking for unknown time.
Old 12-28-2008, 10:34   #6 (permalink)
Member: 87357
Thanks Meter: 9,457
Yes at the Moment SL2 , Server Close , So Be Patience , I hope You can understand
Nokia 5800 xpress Music unlock done with MX-KEY adreesas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-10-2010 15:29
Nokia 5800 xpress Music unlock done with MX-KEY kamranas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-10-2010 15:25
nokia 5310 xpress music unlock code gedawy71 Nokia Base Band 5 ( BB-5 ) 15 08-24-2009 10:51
!!!!!!wow!!!!!!! Nokia 5310 Expres Music Unlock Done meknes gsm Universalbox 5 04-14-2008 09:58
Page generated in 0.17738 seconds with 9 queries
