Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 03-23-2007, 17:13   #1 (permalink)
Member: 434880
2310 unlocking problem
Hi,
I've tried to unlock 4 different 2310's and I've had the same problem with all of them. I've previously unlock maybe 20 of these until now.
The cable (2600) is working fine on other phones.
I have also tried easy cable. no joy.
thanks
dway
Old 03-23-2007, 18:04   #2 (permalink)
EIGY's Avatar
Member: 68075
Originally Posted by dway View Post
Hi,
thanks
dway
Hello! Ma8!
This is cable problem.
Pls! Check cable connect.
Or
You use Easy cable.
B.R.
EIGY.
Old 03-23-2007, 18:11   #3 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Arrow Try this method
DEAR IT's just cable problem u need to do one thing when u put cable in fone keep it hold in the area where pin's connecting in PCB.
try this then post RESULT here
Take Care
Hi,
thanks
dway
Old 03-23-2007, 18:42   #4 (permalink)
alex12345's Avatar
Member: 152573
hi, try clean phone pin and try to plug in cable tightly/change another cable .
With Best Regards
alex
Old 03-23-2007, 18:55   #5 (permalink)
Member: 470775
dont worry
you can flash your phone then you can unlock ur phone because some phones give same problem with me otherwise this is cable fault
Old 03-23-2007, 21:24   #6 (permalink)
Member: 434880
worked in the end afer 3 different easyflash cables.
thanks,
dway
(IS there a list of the error codes anywhere ?)
Old 03-24-2007, 17:38   #7 (permalink)
Member: 143848
i have flashed one 1110 with universal box now the imei is all ??????
how can i repair it
regards
Old 04-04-2007, 16:19   #8 (permalink)
street's Avatar
Member: 24284
HI we need solution with normal cable if you can!!
easy cable work i don't have it sold directly on phnoe i use battery and work!
my resseler don't have it!
Old 04-05-2007, 14:36   #9 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
this problem is not UB .....just cable connector problem .....
Old 04-06-2007, 10:20   #10 (permalink)
street's Avatar
Member: 24284
normal cable don't work my dear work for other models great, just 2310 only easy cable work! but if this is the only way it's not a problm !!!better this then nothing!!lol
Old 04-06-2007, 13:20   #11 (permalink)
deepak2005's Avatar
Member: 253019
i agery with you
wbr
Deepak
Old 04-06-2007, 13:50   #12 (permalink)
EIGY's Avatar
Member: 68075
Hello! Ma8!
100% can be use Fbaus cable!
Same 1100 fbus cable!
B.R.
EIGY.
Old 04-09-2007, 16:05   #13 (permalink)
claudio_gsm's Avatar
Member: 16165
Originally Posted by EIGY View Post
Hello! Ma8!
B.R.
EIGY.
For all operations, u can use EasyCable!!!
But with one condition, go to SW-Menu: Nokia-->DCT4-->FLASH--> and here check option: "Easy flash cable" and there u will not see any more the error:
"TDCT4UnlockThread finished at: 2007/04/09 04:40:40
Terminated with error: TX High after BSI Low [7F000004]. 7E00011E. 00000102. 0000020C. 00011220. 0000040D. 00000101. 0000020C. 0001023A. 000110D0. 000111A2. 00011510. 00011A83. 00011A86"
U got it?¿ !!!
BesT RegardS too all UB users!
2310 unlock problem Lpapp MT-BOX 9 12-27-2006 19:23
2310 unlock problem tical MT-BOX 7 12-16-2006 21:28
2310 unlock problem Bugsy2006 UFS2 + UFS3-Tornadoflasher 25 11-20-2006 12:08
Page generated in 0.34681 seconds with 12 queries
