Universalbox Universalbox Official support area |
12-15-2009, 22:06 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Algeria
Member: 158242 Status: Offline Sonork: 100.1591384 Thanks Meter: 194 | 30 credit lost but not repair sd problem write failed Code: MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 12,05V OK. Output power at Line1 3,93V is in range of: 4,00V ±10,0% Asic ID: 000000010000022600010006010C192101003000 EM Asic ID: 00000232 EM Asic ID: 00000352 Public ID: 20E0000FDB890054CE4DC652736671B78EF63E77 Asic Mode ID: 00 Hash: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Flashing file: BB5 [BB5 ALGORITHM] MCU File: PatchUnlock 0 kB Speed: [3000k, 3250k, 3250k, 98k] Baud. Supported Hardwares: [010C192101003000] Input power: 12,05V OK. Output power at Line1 3,93V is in range of: 4,00V ±10,0% Connecting to server: US4 Boot Loader: RAP3Gv3_2nd.fg 15 kB Version: 1.30.0 Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002] Asic ID: 000000010000022600010006010C192101003000 EM Asic ID: 00000232 EM Asic ID: 00000352 Public ID: 20E0000FDB890054CE4DC652736671B78EF63E77 Asic Mode ID: 00 Hash: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Total time: 28,2 sec. Connecting to server: US4 Credits Left: 413 Superdongle data saved to file D:\Uni\Files\Nokia\BB5\Backup\20E0000FDB890054CE4DC652736671B78EF63E77.SD Initializing phone... Output power at Line1 3,93V is in range of: 4,00V ±10,0% Phone powered. SUPERDONGLE section write failed! [0x0003] Code: MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing phone... Output power at Line1 3,95V is in range of: 4,00V ±10,0% Phone powered. Reading Info... Soft Version: V 06.43 Date: 30-03-07 Type: RM-78 (6280) Pack: (c) Nokia Product code: Product code: Radio: GSM900 / GSM1800 / GSM1900 / WCDMA I Original IMEI: 359382-00-******** Production serial: HW Version: DSP Version: pb05w46v49 LCD Version: SHARP APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: FFFFFFFFFFFFFFFF Simlock config: FFFFFFFFFFFFFFFF Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 00101F Security code: 12345 Executing self tests... Passed [03] ST_TAHVOINT_TEST Passed [0C] ST_EAR_DATA_LOOP_TEST Passed [0D] ST_SIM_CLK_LOOP_TEST Passed [21] ST_SIM_IO_CTRL_LOOP_TEST Passed [0F] ST_SIM_LOCK_TEST Passed [38] ST_SLEEP_X_LOOP_TEST Passed [2E] ST_SLEEPCLK_FREQ_TEST Passed [07] ST_UEM_CBUS_IF_TEST Passed [16] ST_KEYBOARD_STUCK_TEST Passed [14] ST_CAMERA_IF_TEST Passed [15] ST_BACKUP_BATT_TEST Passed [2C] ST_LPRF_IF_TEST Passed [02] ST_LPRF_AUDIO_LINES_TEST Passed [2B] ST_CURRENT_CONS_TEST Not supported [2A] ST_LCD_TEST Passed [25] ST_RADIO_TEST Passed [45] ST_SEC_CAMERA_IF_TEST Passed [5D] ST_BACKLIGHT_TEST Passed [5A] ST_SECURITY_TEST Passed [47] ST_PWR_KEY_TEST Passed [63] ST_BT_WAKEUP_TEST Passed [65] ST_IRDA_LED_STRESS_TEST Passed [6B] ST_BTEMP_TEST Passed [6C] ST_BT_SLEEP_CLK_TEST Passed [00] ST_EXT_DEVICE_TEST -------------------------------------------------------------------------------- TBB5SelfTestThread 2.8.4.2499 finished at: 2009/12/15 22:01:55 Done. TSelfUpdateThread 2.8.4.2499 started at: 2009/12/15 22:03:03 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US4 Receiving latest versions... All available algos are up to date. Current local filepack version: 6.48 is up to date. Current local executable version: 2.8.4.2499 is up to date. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. -------------------------------------------------------------------------------- TSelfUpdateThread 2.8.4.2499 finished at: 2009/12/15 22:03:05 Done. |
12-16-2009, 20:16 | #3 (permalink) |
Member: 158242 Status: Offline Sonork: 100.1591384 Thanks Meter: 194 | i need to know if i repair this phone for second time will ub charge another 30 credit yes or no , because no any chance for refund my 30 credit , i will erase phone and do the repair sd causde first time write failed i used latest version of ub i check phone before it not my fault |
12-16-2009, 20:36 | #4 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420862 Status: Offline Thanks Meter: 51 | I have repaired 3nos 7210 no problem , simple procedure 1- Get info and check that if phone simlock data is corrupt( phone is Contact service ) - Ans- Yes if corrupt , you have to repair phone using repair option which will consume 20 credits 2 Get info from CHECK SD which will tell you that if Superdongle WD is OK or has to be Repaired Ans- If Superdongle is to be repaired you need 30 credits In your case logs show that Sp- area is corrupt SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: FFFFFFFFFFFFFFFF Simlock config: FFFFFFFFFFFFFFFF Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 00101F So you have to repair your phone 1'st then go for SD Total credits required 50 regards rockgsm |
12-16-2009, 20:58 | #5 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | Quote:
Yes, you need again credits for repair or sd | |
credit lost but cant repair w200 gdfs | ali_imran | D-Unlock Suite | 1 | 01-07-2010 18:40 |
30 credit gone but not repair superdongle data -5220 | halim-gsm | Universalbox | 11 | 12-24-2009 12:38 |
credit lost but not repaired gdfs | ..:::YMG:::.. | D-Unlock Suite | 2 | 12-08-2009 12:37 |
