| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007
Member: 587516 Status: Offline Thanks: 16
| 6680 hang when charging bro i have 6680 here..the phone is ok if u r not using it..but when u try use the phone it will automatically shuts off after an hour..and i also noticed that when i charge it..the phone hangs up..i tried to flash the phone with higher and lower version but no luck...pls replay if you have any solution.. ... |
| | #2 (permalink) |
| what can we do with this problem sir!!! last month i had 6680 that shows charging even the charger was removed, and now i do have 6630 thats has the same problem with my 6680 last month!!! what could it be sir!!! it shuts down 30 to 45 minutes!! its almost the same with the one i had?!! anybody could help me sir!! thanks!!!! evrytime i charge it after a few minutes, the lights off!! even you press a key lights don't flash!!! it hangs!!!! when i pulled the charger, the charging indicator still running!!! help me sir!!!! |
| | #3 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: Ireland » Dublin » City Center Age: 26
Member: 87357 Status: Offline Sonork: 100.1574043 Thanks: 366
| its look like hardware problem ,have You check hardware section . Regards Faisal |
| | #4 (permalink) |
| hi sir!! i've been checking its part since then and now here comes a 6630 that has the same problem!! i've gone to schematic, checked its connection, i tried replacing it, but nothing happens!! please help me sir to repair this problem, is there any tricks or what could be the cause of it!! thank you sir for the response!! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
