A2 PLATFORM Z750i NOT SUPPORTED FOR UNLOCK HI, I WAS TRYING TO UNLOCK A A2 PLATFORM Z750i, BUT ALWAYS I GET ERROR TERMINATED WITH ERROR: INVALID MODEL SELECTED. THE ERROR MESSAGE IS SAME EVEN FOR COMMANDS LIKE READ INFO OR RESET USER CODE. HOW TO SOLVE THE PROBLEM? BR jackle123 |
Have you Update you box? & Post here Screen shot, Regards F@iSaL |
I upgraded and not support him for anything Gentlemen N€XXUS63 |
I had the same problem, but you just use k850 model and you are done. Post results. W.B.R. |
Pls post here screen shots. B.R. EIGY.:D |
Post here Screen shot or log file then we able to help you Regards F@iSaL |
The hand set has been returned, as the customer had to leave. But may be will get back by 2rrow. But The following is the log from log file MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! Terminated with error: Invalid model selected. [C8020401] [0002449E].00024478 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [********] Hope this log is sufficient. OR Should I try selecting K850 as Mr kelvinator has said. Br jackle123 |
K850 conect USB Push holad "C" Then You try open device manager. Then re-install SE driver. B.R. EIGY.:D |
THANK YOU VERY MUCH UB TEAM. I HAVE UNLOKED THE Z750i MODEL SELECTING K850 UNDER A2 PLATFORM. HERE IS THE SUCCESSFUL LOG MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! OTP IMEI/CID/PAF: ****************** / 52 / 1 LangPackage: HUTCH-WORLD CDA: 1208-1506 Revision: R2A CXC: 1200-8914 Soft version: R1ED001 Initializing GDFS... Connecting to server: US2 Credits: *** Credits Left: *** -------------------------------------------------------------------------------- TUMTSSendSECSLogThread finished at: 2008/10/28 11:19:07 Done. TUMTSGetSECSResultThread started at: 2008/10/28 11:28:04 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! OTP IMEI/CID/PAF: ****************** / 52 / 1 LangPackage: HUTCH-WORLD CDA: 1208-1506 Revision: R2A CXC: 1200-8914 Soft version: R1ED001 Phone Color: RED. Phone CID: 52. Loader version: 2008-07-14 12:03 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A064 Loader version: 2008-07-14 12:07 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A064 Loader version: 2008-07-14 12:06 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A064 Connecting to server: US2 Initializing GDFS... SIMLock signed succesfully. Leaving test mode... -------------------------------------------------------------------------------- TUMTSGetSECSResultThread finished at: 2008/10/28 11:28:23 Done. TUMTSCSCAActivateThread started at: 2008/10/28 11:28:30 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US2 Asking service availability... Please turn on the phone, and connect it to the DCU-60 cable Port found at: Sony Ericsson Device 117 USB WMC Device Management Connecting to server: US2 Credits: *** Please wait! This can take several minutes... Credits left: *** DCRCs calculated successfully. Waiting the phone to turn off... -------------------------------------------------------------------------------- TUMTSCSCAActivateThread finished at: 2008/10/28 11:30:20 Done. THANKS AND BR jackle123 |
same prob with me while selecting z750 i model |
Trust me mates, use the model I said in my post (K850). W.B.R. |
use v640 will ok .... TA2ReadInfoThread started at: 2008-10-31 19:43:52 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! OTP IMEI/CID/PAF: ****************** / 52 / 1 LangPackage: APAC-ANZ CDA: CDA102295/1 Revision: R11A CXC: 1200-8914 Soft version: R1EA030 Phone Color: RED. Phone CID: 52. Loader version: 2008-07-14 12:03 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A064 Loader version: 2008-07-14 12:07 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A064 Loader version: 2008-07-14 12:06 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A064 Leaving test mode... -------------------------------------------------------------------------------- TA2ReadInfoThread finished at: 2008-10-31 19:44:03 Done. TUMTSSendSECSLogThread started at: 2008-10-31 19:44:14 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! OTP IMEI/CID/PAF: ****************** / 52 / 1 LangPackage: APAC-ANZ CDA: CDA102295/1 Revision: R11A CXC: 1200-8914 Soft version: R1EA030 Initializing GDFS... Connecting to server: US2 Credits: 256 Credits Left: 246 -------------------------------------------------------------------------------- TUMTSSendSECSLogThread finished at: 2008-10-31 19:44:25 Done. TUMTSGetSECSResultThread started at: 2008-10-31 20:21:28 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! OTP IMEI/CID/PAF: ****************** / 52 / 1 LangPackage: APAC-ANZ CDA: CDA102295/1 Revision: R11A CXC: 1200-8914 Soft version: R1EA030 Phone Color: RED. Phone CID: 52. Loader version: 2008-07-14 12:03 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A064 Loader version: 2008-07-14 12:07 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A064 Loader version: 2008-07-14 12:06 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A064 Connecting to server: US2 Initializing GDFS... SIMLock signed succesfully. Leaving test mode... -------------------------------------------------------------------------------- TUMTSGetSECSResultThread finished at: 2008-10-31 20:21:45 Done. TUMTSCSCAActivateThread started at: 2008-10-31 20:21:50 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US2 Asking service availability... Please turn on the phone, and connect it to the DCU-60 cable Port found at: Sony Ericsson Device 117 USB WMC Device Management Connecting to server: US2 Credits: 246 Please wait! This can take several minutes... Credits left: 236 DCRCs calculated successfully. Waiting the phone to turn off... -------------------------------------------------------------------------------- TUMTSCSCAActivateThread finished at: 2008-10-31 20:23:17 Done. |
I cant unlock TUniversalForm 2.7.4.2048 started at: 2009/03/18 20:48:00 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Authenticating software... Device opened at USB->Universal Box [UBD9VWZN] TSelfUpdateThread 2.7.4.2048 started at: 2009/03/18 20:48:02 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US3 Receiving latest versions... All available algos are up to date. Current local filepack version: 5.11 is up to date. Current local executable version: 2.7.4.2048 is up to date. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. -------------------------------------------------------------------------------- TSelfUpdateThread 2.7.4.2048 finished at: 2009/03/18 20:48:05 Done. TA2ReadInfoThread 2.7.4.2048 started at: 2009/03/18 20:48:15 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the C key! OTP IMEI/CID/PAF: 358936-01-******** / 52 / 1 LangPackage: AMERICA CDA: 1203-1784 Revision: R2A CXC: 1200-8914 Soft version: R1CA029 Phone Color: RED. Phone CID: 52. Loader version: 2008-10-09 14:24 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A071 Loader version: 2008-07-14 12:07 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A064 Loader version: 2008-07-14 12:06 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A064 Leaving test mode... -------------------------------------------------------------------------------- TA2ReadInfoThread 2.7.4.2048 finished at: 2009/03/18 20:48:47 Done. TA2UnlockThread 2.7.4.2048 started at: 2009/03/18 20:48:53 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Please turn on the phone while pressing the 2+5 keys! Phone Color: RED. Phone CID: 52. OTP IMEI: 358936-01-******** Loader version: 2008-10-09 14:24 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A071 Loader version: 2008-10-09 14:22 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 71 Hardware key: 00000000000000000000000000000000 Hardware key invalid -------------------------------------------------------------------------------- TA2UnlockThread 2.7.4.2048 finished at: 2009/03/18 20:49:13 Terminated with error: 0001401C.00021003.0002A051.0002A05B.0002A1D4.0002A 1E2 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBD9VWZN] an now I have "this: Hardware key invalid" what is it. I try to unlock selecting K850 but nothing, when select Z750 and read infor "wrong model selected" wwhen I try to unlock "wrong model selected" Please, I have the most updated universalbox software. I unlock directly of line some K850 without any problems but this Z750 can´t. Thanks. |
Damn it... I selected k850 from menu and pressed UNLOCK, Seems that tried to write erom k850.erom file, but failed now the phone is dead... If i tried to flash pressing C i cant get nothing.... Can anybody help me please!!! My *******r wanna kills me! THANKS |
