Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 10-25-2008, 07:48   #1 (permalink)
Member: 138575
A2 PLATFORM Z750i NOT SUPPORTED FOR UNLOCK
HI,
I WAS TRYING TO UNLOCK A A2 PLATFORM Z750i, BUT ALWAYS I GET ERROR
TERMINATED WITH ERROR: INVALID MODEL SELECTED. THE ERROR MESSAGE IS SAME EVEN FOR COMMANDS LIKE READ INFO OR RESET USER CODE.
HOW TO SOLVE THE PROBLEM?
jackle123
Old 10-25-2008, 08:42   #2 (permalink)
MobilesDoctor's Avatar
Member: 87357
Sonork: 100.1574043
Have you Update you box? & Post here Screen shot,
Regards
F@iSaL
Old 10-25-2008, 19:00   #3 (permalink)
Moderator
Braycel's Avatar
Member: 813309
I upgraded and not support him for anything Gentlemen
N€XXUS63
Old 10-25-2008, 19:49   #4 (permalink)
kelvinator's Avatar
Member: 262145
I had the same problem, but you just use k850 model and you are done.
Post results.
W.B.R.
Old 10-26-2008, 11:31   #5 (permalink)
bimes's Avatar
Member: 729381
N€XXUS63
are you sure you updated it
Old 10-26-2008, 14:51   #6 (permalink)
EIGY's Avatar
Member: 68075
N€XXUS63
Post results.
W.B.R.
Hello Ma8!
Pls post here screen shots.
B.R.
EIGY.
Old 10-27-2008, 09:58   #7 (permalink)
Member: 87357
Sonork: 100.1574043
Post here Screen shot or log file then we able to help you
Regards
F@iSaL
Old 10-27-2008, 10:51   #8 (permalink)
Member: 138575
The hand set has been returned, as the customer had to leave. But may be will get back by 2rrow. But The following is the log from log file
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Please turn on the phone while pressing the C key!
Terminated with error: Invalid model selected. [C8020401] [0002449E].00024478
Device opened at USB->Universal Box [********]
Hope this log is sufficient.
OR
Should I try selecting K850 as Mr kelvinator has said.
jackle123
Old 10-27-2008, 13:39   #9 (permalink)
EIGY's Avatar
Member: 68075
OR
jackle123
Hello Ma8!
K850 conect USB Push holad "C"
Then You try open device manager.
Then re-install SE driver.
B.R.
EIGY.
Old 10-28-2008, 07:12   #10 (permalink)
Member: 138575
THANK YOU VERY MUCH UB TEAM. I HAVE UNLOKED THE Z750i MODEL SELECTING K850 UNDER A2 PLATFORM. HERE IS THE SUCCESSFUL LOG
OTP IMEI/CID/PAF: ****************** / 52 / 1
LangPackage: HUTCH-WORLD
CDA: 1208-1506
Revision: R2A
CXC: 1200-8914
Soft version: R1ED001
Initializing GDFS...
Connecting to server: US2
Credits: ***
Credits Left: ***
TUMTSSendSECSLogThread finished at: 2008/10/28 11:19:07
Done.
TUMTSGetSECSResultThread started at: 2008/10/28 11:28:04
CDA: 1208-1506
Revision: R2A
CXC: 1200-8914
Phone Color: RED.
Phone CID: 52.
Loader version: 2008-07-14 12:03 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A064
Loader version: 2008-07-14 12:07 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A064
Loader version: 2008-07-14 12:06 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A064
SIMLock signed succesfully.
Leaving test mode...
TUMTSGetSECSResultThread finished at: 2008/10/28 11:28:23
Done.
TUMTSCSCAActivateThread started at: 2008/10/28 11:28:30
Asking service availability...
Please turn on the phone, and connect it to the DCU-60 cable
Port found at: Sony Ericsson Device 117 USB WMC Device Management
Credits: ***
Please wait! This can take several minutes...
Credits left: ***
DCRCs calculated successfully.
Waiting the phone to turn off...
TUMTSCSCAActivateThread finished at: 2008/10/28 11:30:20
Done.
THANKS AND BR
jackle123
Old 10-28-2008, 12:42   #11 (permalink)
Member: 770769
Sonork: 100.1579718
same prob with me while selecting z750 i model
Old 11-01-2008, 00:38   #12 (permalink)
kelvinator's Avatar
Member: 262145
Trust me mates, use the model I said in my post (K850).
W.B.R.
Old 11-01-2008, 05:06   #13 (permalink)
Member: 726373
use v640 will ok ....
TA2ReadInfoThread started at: 2008-10-31 19:43:52
LangPackage: APAC-ANZ
CDA: CDA102295/1
Revision: R11A
CXC: 1200-8914
Soft version: R1EA030
Phone Color: RED.
Phone CID: 52.
TA2ReadInfoThread finished at: 2008-10-31 19:44:03
Done.
TUMTSSendSECSLogThread started at: 2008-10-31 19:44:14
CDA: CDA102295/1
Revision: R11A
CXC: 1200-8914
Credits: 256
Credits Left: 246
TUMTSSendSECSLogThread finished at: 2008-10-31 19:44:25
Done.
TUMTSGetSECSResultThread started at: 2008-10-31 20:21:28
CDA: CDA102295/1
Revision: R11A
CXC: 1200-8914
Phone Color: RED.
Phone CID: 52.
TUMTSGetSECSResultThread finished at: 2008-10-31 20:21:45
Done.
TUMTSCSCAActivateThread started at: 2008-10-31 20:21:50
Credits: 246
Credits left: 236
TUMTSCSCAActivateThread finished at: 2008-10-31 20:23:17
Done.
Old 03-19-2009, 00:57   #14 (permalink)
Crazy Poster
Member: 618371
I cant unlock
TUniversalForm 2.7.4.2048 started at: 2009/03/18 20:48:00
Authenticating software...
Device opened at USB->Universal Box [UBD9VWZN]
TSelfUpdateThread 2.7.4.2048 started at: 2009/03/18 20:48:02
Connecting to server: US3
Receiving latest versions...
All available algos are up to date.
Current local filepack version: 5.11 is up to date.
Current local executable version: 2.7.4.2048 is up to date.
TSelfUpdateThread 2.7.4.2048 finished at: 2009/03/18 20:48:05
Done.
TA2ReadInfoThread 2.7.4.2048 started at: 2009/03/18 20:48:15
OTP IMEI/CID/PAF: 358936-01-******** / 52 / 1
LangPackage: AMERICA
CDA: 1203-1784
Revision: R2A
CXC: 1200-8914
Soft version: R1CA029
Phone Color: RED.
Phone CID: 52.
Loader version: 2008-10-09 14:24 CXC1250776_DB31XX_PRE_LOADER_APP_SDRAM_R2A071
TA2ReadInfoThread 2.7.4.2048 finished at: 2009/03/18 20:48:47
Done.
TA2UnlockThread 2.7.4.2048 started at: 2009/03/18 20:48:53
Please turn on the phone while pressing the 2+5 keys!
Phone Color: RED.
Phone CID: 52.
OTP IMEI: 358936-01-********
Loader version: 2008-10-09 14:22 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 71
Hardware key: 00000000000000000000000000000000
Hardware key invalid
TA2UnlockThread 2.7.4.2048 finished at: 2009/03/18 20:49:13
Terminated with error: 0001401C.00021003.0002A051.0002A05B.0002A1D4.0002A 1E2
an now I have "this: Hardware key invalid" what is it.
I try to unlock selecting K850 but nothing, when select Z750 and read infor "wrong model selected" wwhen I try to unlock "wrong model selected"
Please, I have the most updated universalbox software. I unlock directly of line some K850 without any problems but this Z750 can´t.
Thanks.
Old 03-21-2009, 17:48   #15 (permalink)
rushwhq's Avatar
Member: 172399
Damn it...
I selected k850 from menu and pressed UNLOCK, Seems that tried to write erom k850.erom file, but failed now the phone is dead...
If i tried to flash pressing C i cant get nothing....
Can anybody help me please!!! My *******r wanna kills me!
THANKS
@Infinity Support new FW for ZTE i766 not supported for unlock cubafreak Infinity-Box 12 11-26-2009 15:09
6234 supported or not supported for unlock boucettay BB5KING for (BB5BOX) 10 10-27-2008 20:33
Sorry, this version is not supported for unlock! Contact support! PhoneCareCenter Multi-box LITE 7 05-09-2008 19:28
There is new version ot *** not supported for unlock Bobi VygisToolbox 1 04-08-2005 06:49
G5400 from 02 is not supported for unlocking??? AE177 Blazer 1 11-02-2004 12:23
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 2.13558 seconds with 8 queries
