Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Universalbox Universalbox Official support area |
| | #32 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2007 Location: rasht
Member: 436596 Status: Online Thanks: 48
| there is a bug in new version. when you want to flash a bb5 phone in usb mode (dead phone) and check "read certificate" after creating back up an error accures. Last edited by sabeti; 09-27-2008 at 18:19. Reason: bad en |
| | #33 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2004 Age: 37
Member: 68982 Status: Offline Thanks: 747
| Quote:
can you try to install it to c drive, and then move uni directory to g drive. | |
| | #34 (permalink) | |
| Quote:
This is supported only with working phone via fbus connection. In next comming updates we will support pm 308 backup before usb flash but certificate backup is not possible. | |
| | #35 (permalink) | |
| Quote:
first you should check mark save certificate after error uncheck save certificate and flash phone. in newest version when you do it universal.exe terminated and windows want to send error report to server. | |
| | #36 (permalink) |
| TBB5FlashPhoneThread started at: 2008/09/27 21:42:46 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Flashing file: BB5 [BB5 ALGORITHM] MCU File: rm146__05.50.mcusw 14 885 kB Speed: [3250k, 6500k, 6500k, 98k] Baud. Supported Hardwares: [0103192101001101, 010C192101001101] Input power: 11.93V OK. Output power at Line1 3.95V is in range of: 4.00V ±10.0% -------------------------------------------------------------------------------- TBB5FlashPhoneThread finished at: 2008/09/27 21:42:54 Terminated with error: 000100A6.000100A8.000100B8.0001102C.000115E0 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQUNEE9] |
| | #42 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Age: 30
Member: 185279 Status: Offline Thanks: 82
| Hi, when I close the software say: "Unable to write to C:\Uni\uni.ini" and don't close it. I have 3 PCs and only in one fail, I don't understand where is the problem, Im using the last version, uninstall and install again and the same problem. Please help me ![]() PS: I uninstall CA Antivirus Software and now is working fine... =) |
| | #43 (permalink) |
| Member deceased !! ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Pakistan
Member: 390175 Status: Offline Thanks: 5
| any n95 always giving this error on ok cable checked on ufs 7 pin error is here TBB5FlashPhoneThread started at: 2008/09/30 10:14:08 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Flashing file: BB5 [XSR 1.5] MCU File: RM-159_21.0.016_PR.C0R 72 381 kB Speed: [51k, 6500k, 6500k, 98k] Baud. Supported Hardwares: [4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103] Supported APE Hardwares: [24200705] Input power: 4.70V OK. Output power at Line1 3.97V is in range of: 4.00V ±10.0% -------------------------------------------------------------------------------- TBB5FlashPhoneThread finished at: 2008/09/30 10:14:16 Terminated with error: 000100A6.000100A8.000100B8.0001102C.000115E0 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBEFLMXM] |
| | #44 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2005 Location: CHILE Age: 38
Member: 156248 Status: Offline Thanks: 305
| 6131 No Flash FBUS v 2.5.8.1821 Update to 2.5.8.1821 and no flash 6131 by FBUS. Code: TBB5ReadInfoThread started at: 2008-09-30 11:39:38 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Initializing phone... Output power at Line1 3,95V is in range of: 4,00V ±10,0% Phone powered. Reading Info... MCU Version: V 06.10 Date: 16-02-07 Type: RM-115 (6131) Additional_1: (c) Nokia. PPM Version: V 06.10 Date: 16-02-07 Type: RM-115 (6131) Pack: (c) Nokia. Product code: 0534190 Original IMEI: ****************** Production serial: RJK876560 HW Version: 3011 DSP Version: dsp_mojito_05w46v48.1 LCD Version: APE ADSP Version: SIMLock service: SIMLOCK SERVER VERSION 63 [040A07050C0E] Profile bits: 0000000000000000 Simlock config: 7300100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 73001F Block: 2; Lock: 1; State: Closed; Data: 73010F Block: 3; Lock: 1; State: Closed; Data: 73001F Block: 4; Lock: 1; State: Closed; Data: 73010F Security code: 12345 -------------------------------------------------------------------------------- TBB5ReadInfoThread finished at: 2008-09-30 11:40:23 Done. BB5 [BB5 ALGORITHM] PPM File: rm115__06.10.ppm_l 3 727 kB Languages: English, Croatian, German, Slovenian, Serbian Latin Speed: [3250k, 6500k, 6500k, 98k] Baud. Supported Hardwares: [0103192101001101, 010C192101001101] BB5 [BB5 ALGORITHM] UCP File: rm115__06.10.image_L_Entel 6 664 kB Speed: [3250k, 6500k, 6500k, 98k] Baud. Supported Hardwares: [0103192101001101, 010C192101001101] BB5 [BB5 ALGORITHM] MCU File: rm115__06.10.mcusw 13 258 kB Speed: [3250k, 6500k, 6500k, 98k] Baud. Supported Hardwares: [0103192101001101, 010C192101001101] TBB5FlashPhoneThread started at: 2008-09-30 11:40:40 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Flashing file: BB5 [BB5 ALGORITHM] MCU File: rm115__06.10.mcusw 13 258 kB Speed: [3250k, 6500k, 6500k, 98k] Baud. Supported Hardwares: [0103192101001101, 010C192101001101] Input power: 11,91V OK. Output power at Line1 3,95V is in range of: 4,00V ±10,0% Boot Loader: RAP3Gv3_2nd_fps8.fg 15 kB Version: 1.20.2 Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002] Max Flash Devices: 1 Flash ID 1: 00010041 - 0000 Rev: 6A21 Manufacturer: AMD MSB: 00 SectorSize: 0x020000 Signature: 00000000000000000000000000000000 Asic ID: 000000010000022600010006010C192101001101 EM Asic ID: 00000232 EM Asic ID: 00000353 Public ID: 0CE0000856A86D560DCE925A1FF64C85D45A43D3 Asic Mode ID: 00 Hash: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F -------------------------------------------------------------------------------- TBB5FlashPhoneThread finished at: 2008-09-30 11:40:55 Terminated with error: No available flashloader for this HW/Flash ID [000110EA].00011166.00011176.000115E0 |
| | #45 (permalink) | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Bugs in the last software version and things to do | Reibak | Cyclonebox | 67 | 01-05-2010 16:04 |
| bugs and things to do pls post here any problem on 1.28 | shoktong | MSS Box II | 1 | 12-08-2009 00:26 |
| How to Be Your Little Man's Dad: 365 Things to Do with Your Son | IPMART | ipmart WebShop | 0 | 10-13-2009 14:00 |
| What is the Next thing to do? | cellcom_salazar | Easy-Unlocker | 3 | 09-13-2008 06:52 |
| It is posible to change imei with griffin,and how to do it? | VREDNYJ | Griffin | 6 | 09-27-2004 16:08 |
