Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Universalbox Universalbox Official support area |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks: 2
| can i repair gdfs area using universal box? i have a k800i dead.customer said that removed battery when turn on(i mean without turn off) .then never can not turn on. i have cruiser and setool.in both can not on it.i have not universal box.if it can, i should buy it. setool logs as below when clicked in identify got as below Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED set_gdfs_props failed, exiting Elapsed:7 secs. then i tried to flash using 49 files after tick two options in SETTINGS. complete the phone and use server for unlock/flash and got as below Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 Flash ID check:2019 Flash props sent ok writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_1250568_HUTCHISON_WI.ssw.cry CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing E:\may2007\students cd\25.SE TOOL\flash files\k800\FROM SETOOL NET\R1EJ001_HUTCH_1_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses complete hash, hash len is:4420 Will flash 221 blocks... SSW loading returns:0 CSloader version: 061027 1723 HANCXC1250562_DB2020_CSLOADER_R3A005 loader startup: executed loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed:613 secs. flashing main and fs no problem.but an error during complete the phone . '''''''loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal'''''''''' FROM FAQ I UNDERSTOOD THAT GDFS SERVICES ERROR 29 IS DUE TO EROM. SO I TRIED TO UPGRADE BY PRESS AND HOLD 2 AND 5 AND GOT AN ERROR MESSAGE AS BELOW SERVER SUPPORT ENABLED. RECOVERY MODE STARTED DB2020 EROM UPGRADE STARTED OLD EROM, OVERRIDING CID error while reading security units SECURITY UNITS CAN'T BE READ ! PHONE IS EMPTY OR GDFS IS DAMAGED. Elapsed:9 secs. FROM FAQ I UNDERSTOOD THE FOLLOWING """"""read the security zones using the TXT file you must create gdfsread:00020e5a gdfsread:00020e48 gdfsread:00010851 gdfsread:00000006 gdfsread:0000000E gdfsread:00000013 gdfsread:0000001C gdfsread:00000018 gdfsread:000000AA .After that Write working GDFS with "Format when writing GDFS" checked. After that, write (as script) your GDFS zone backuped with TXT file ."""""" as in above note i tried backup my k800i dead security zone area using the text file readsecunits.txt got an error message as below """"""ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601775701 CERT:RED FLASH CID:49 COLOR:RED phone CID not supported in that mode Elapsed:7 secs."""" sometimes error message as below """ChipID:9900,EMP protocol:0301 OLD EROM, OVERRIDING CID error while reading security units SECURITY UNITS CAN'T BE READ ! PHONE IS EMPTY OR GDFS IS DAMAGED. Elapsed:10 secs.""""" so my doubt are can i repair above error message in UNIVERSAL BOX? can i write the gdfs from another working phone? is it damaged the phone permanenly? thank u |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2004 Age: 34
Member: 54900 Status: Offline Thanks: 26
| Try this attached your phone to cruiser repair EPPROm is hightlited do that de attached the phone remove battery now inset it again and power on the cell it should be on now tested thi more then 10 times 100% working if you have not yet destroyed the gdfs. try and post your results. thanks |
| | #3 (permalink) |
| Junior Member Join Date: Apr 2007
Member: 483035 Status: Offline Thanks: 6
| I'm having this problem flashing with smartcard: TUMTSFlashPhoneThread started at: 2007/10/03 15:17:35 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Connecting to server: US Asking service availability... Output power at Line1 3,95V is in range of: 4,00V ±10,0% Output power at Line2 4,74V is in range of: 5,00V ±25,0% Please turn on the phone! Serial line 1 speed changed to 460kBaud. Trying to send loader... OTP IMEI/CID/PAF: 357445-00-538625-X / 49 / 1 First FlashID: 890D Phone Color: RED. Phone CID: 49. Serial line 1 speed changed to 920kBaud. Flashing software file: W600_R7CA017_GENERIC_CID49R Flash time: 6:09,8 sec. Flashing generic language file: W600_R7CA017_AMERICA_2_CID49R Flash time: 4:06,2 sec. Leaving test mode... Output power at Line1 3,95V is in range of: 4,00V ±10,0% Output power at Line2 4,74V is in range of: 5,00V ±25,0% Serial line 1 speed changed to 460kBaud. Entering explorer mode... OTP IMEI/CID/PAF: 357445-00-538625-X / 49 / 1 -------------------------------------------------------------------------------- TUMTSFlashPhoneThread finished at: 2007/10/03 15:30:21 Terminated with error: 0002E010.Error initializing filesystem [00025370] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBD8PLAM] TUMTSReadInfoThread started at: 2007/10/03 15:30:51 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3,95V is in range of: 4,00V ±10,0% Output power at Line2 4,74V is in range of: 5,00V ±25,0% Please turn on the phone! Serial line 1 speed changed to 460kBaud. Trying to send loader... OTP IMEI/CID/PAF: 357445-00-538625-X / 49 / 1 First FlashID: 890D Phone Color: RED. Phone CID: 49. Initializing GDFS... Reading phone software version... Hardware ID: 040 GDFS IMEI/CID/PAF: 000000-25-000000-0 / 16 / 0 Warning! OTP IMEI, and GDFS IMEI are not the same! Make sure you flashed the phone with patched software! Invalid Lock Code info: 7ECE061000 Phone software version: LangPackage: CDA: Revision: Leaving test mode... -------------------------------------------------------------------------------- TUMTSReadInfoThread finished at: 2007/10/03 15:31:07 Done. Had the same error via testpoint. Can anyone help me with this??? |
| | #4 (permalink) |
| This is my testpoint error: TUMTSReadInfoThread started at: 2007/10/03 17:57:37 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3,95V is in range of: 4,00V ±10,0% Output power at Line2 4,74V is in range of: 5,00V ±25,0% Please turn on the phone! Serial line 1 speed changed to 460kBaud. OTP IMEI/CID/PAF: 357445-00-539364-X / 49 / 1 Loader version: Jan 29 2007 13:48:38 DB2010_SEMC_GENERICLOADER Memories: 3 Memory #1: Flash Base: 0x44000000 Size: 32 MB Manufacturer: Intel ID: 0x880D Buffer size: 64 bytes Unique ID: 1D46B301BC43836B Memory #2: RAM Base: 0x4C000000 Size: 8 MB Memory #3: NANDFlash Base: 0x50000000 Size: 256 MB Manufacturer: ST ID: 0x00AA Entered test mode. Phone CID: 29. Initializing GDFS... GDFS Base: 0x45F00000 Size: 1 MB BlockSize: 128 KB Blocks: 8 Free: 972 KB Used: 35 KB Junk: 824 bytes Reading phone software version... Hardware ID: 040 GDFS IMEI/CID/PAF: 357445-00-539364-X / 49 / 1 Lock Code: 0000 Phone software version: R7CA017 prgCXC1123106_GENERIC_EE LangPackage: CDA: Revision: Leaving test mode... Output power at Line1 3,95V is in range of: 4,00V ±10,0% Output power at Line2 4,74V is in range of: 5,00V ±25,0% Serial line 1 speed changed to 460kBaud. OTP IMEI/CID/PAF: 357445-00-539364-X / 49 / 1 Loader version: Jan 29 2007 13:48:38 DB2010_SEMC_GENERICLOADER Memories: 3 Memory #1: Flash Base: 0x44000000 Size: 32 MB Manufacturer: Intel ID: 0x880D Buffer size: 64 bytes Unique ID: 1D46B301BC43836B Memory #2: RAM Base: 0x4C000000 Size: 8 MB Memory #3: NANDFlash Base: 0x50000000 Size: 256 MB Manufacturer: ST ID: 0x00AA Entered test mode. Phone CID: 29. Entering signature mode... -------------------------------------------------------------------------------- TUMTSReadInfoThread finished at: 2007/10/03 17:58:27 Terminated with error: 00024A32.00024642.00025292 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBD8PLAM] '''''''''''''''''''''''''''''''''''''''''''''''''' ''''''''' Please, UB Team.... Help me!!!!! |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jan 2005 Location: My Bb PiN 268748E5
Member: 106346 Status: Offline Sonork: 100.1577684 Thanks: 951
| download the rest file from se tools site and write it to fone then u can then flash the phone with cruiser but i think ub can help u cos it has never disappoint me in any flashing |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Genie-Universal can fix/repair CS caused by other Boxes | gsmdeluxe | Genie Universal | 0 | 03-10-2009 18:47 |
| how to repair damage gdfs area by universel box | sudarshan 007 | Universalbox | 1 | 01-30-2009 19:34 |
| how we can flash w550i by using universal box | lolipolimobile | Universalbox | 2 | 10-20-2007 14:50 |
| can format user area using Mt-Box | GHOST_GSM | MT-BOX | 1 | 09-21-2006 21:18 |
| FIRST (TM) solution to repair GDFS area in K700 | vee | TOTAL MultiServer | 0 | 12-08-2004 22:13 |
