Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 11-19-2006, 09:05   #1 (permalink)
cskok2003's Avatar
Member: 43057
can universalbox repair contact service and write rpl for asic 11 phone
can universalbox repair contact service and write rpl for asic 11 phone?
Old 11-19-2006, 13:01   #2 (permalink)
Member: 3531
Yes if you replace uem.
Old 11-19-2006, 14:40   #3 (permalink)
3stanGsm's Avatar
Member: 331390
how can we replace the uem if we cant write rpl into it?
Old 11-19-2006, 14:41   #4 (permalink)
Member: 3531
You can write uem ONLY if uem is empty, you cant write uem which is not empty.
Old 11-20-2006, 12:08   #5 (permalink)
universalbox's Avatar
Member: 68982
It can repair contact service, if the simlock data is corrupt. Cannot repair if the flash checksum is damaged.
Old 11-20-2006, 14:03   #6 (permalink)
cskok2003's Avatar
Member: 43057
I mean is the empty phone we can write rpl and unlock it?
Old 11-21-2006, 11:43   #7 (permalink)
Member: 146744
in few words.. we need this RIGHT?
Repair manual for downgraded 1112, 2310 and 2610
Old 11-21-2006, 11:56   #8 (permalink)
Member: 68982
Theoretically you can write RPL, but we can't calculate it yet. Since we don't have RPL we can't try it.
Old 11-21-2006, 11:57   #9 (permalink)
Member: 68982
Possible to do with Uni too. We are going to make a manual.
Old 11-22-2006, 02:17   #10 (permalink)
Member: 146744
i saw that you had busy day with updates yesterday.. i hope when you solve those issues, than You'll make manual as promised....
Old 11-30-2006, 20:09   #11 (permalink)
Member: 146744
We are still waiting for that promised manual 10 days ago....i hope that you'll make one when You come back from your trip.
Old 11-30-2006, 20:26   #12 (permalink)
Member: 19041
ok solution is easy flash news flash ( 2610 - 3.77 )
flash+factory default+ unlock
this method work fine im test my 2610
Old 01-10-2007, 19:11   #13 (permalink)
Cryspim's Avatar
Member: 62561
Well, 2310 by mistake clicked in "patch imei" functions...no signal after this. Reflash the phone, and IMEI = ???????????????. Converted to 1600. Works ok, signal ok, patched again to correct IMEI ok. Trying to convert back to 2310 (UFS-X Manual erase 013F0000-013FFFFF) and flashed back 2310 MCU, PPM, CNT and PM. IMEI area corrected, but aways results "CONTACT SERVICE". I was recovered many 2310 downgraded to 1600 before, but i think that something is wrong with this once, because it was previously patched for disable otp. Try to make fullerase, all things..."CONTACT SERVICE" ever... Convertered back to 1600 and works ok, but can not take it back to 2310. How adress to erase the IMEI patch area?
b.r.
Cryspim
3500c, 6300, 5200 Contact Service After Write RPL yeerk05 Nokia Base Band 5 ( BB-5 ) 11 03-27-2009 05:59
5310 contact service after write rpl &pm ahmad askari Nokia Base Band 5 ( BB-5 ) 5 02-26-2009 23:51
contacts service after write rpl hicham6600 allGSMunlock MultiOnline Remote Server 9 02-03-2008 08:00
nokia 5200 contact service after write rpl ryaz1993. MT-BOX 8 09-13-2007 14:45
Page generated in 0.44461 seconds with 11 queries
