CONFIG KEY: 0000000000000000 is there any way to repair this! @ALL Hi! i have few pcs of the 6500s which have the sp area corrupt (see log below) i need to know if there's any way i can repair this phones thru ay solution apart from RPL files? pls inform? FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 08.30 03-07-08 RM-240 (c) Nokia HW version: 1000 PCI version: RFIC version: 17141715 DSP version: ICPR71_08w22 LCD version: SEIKO PPM version: V 08.30 03-07-08 RM-240 (c) Nokia E BT MCM version: 2222-143 Retu version: 15 Tahvo version: 22 Content Pack version: Content: e V 08.30 03-07-08 RM-240 (c) Nokia Production serial number: CZA393290 Product code: 0543754 Module code: 0203327 Basic production code: 0543753 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 3530770283xxxx3 (edited) IMEI spare to net: 3A 35 70 07 82 93 96 09 IMEI SV to net: 33 35 70 07 82 93 96 59 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 WBR ReyTech. :confused: |
Try to use X-SIM or some other card that is used in using locked phone with any SIM. Other and only solution is RPL. |
unlock with, but u will have problem phone switching off after 10 mins or so. |
batter way use ask to rpl service !!! |
repair rpl 100% tested brother |
only new rpl file cane slove ur problem as i think |
yes only rpl help ;) |
try to repair sl security hopefully recover good luck |
