Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 01-21-2009, 12:43   #1 (permalink)
Crazy Poster
Member: 831294
CONFIG KEY: 0000000000000000 is there any way to repair this!
@ALL
Hi! i have few pcs of the 6500s which have the sp area corrupt (see log below) i need to know if there's any way i can repair
this phones thru ay solution apart from RPL files? pls inform?
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 08.30
03-07-08
RM-240
(c) Nokia
HW version: 1000
PCI version:
RFIC version:  17141715
DSP version:
ICPR71_08w22
LCD version: SEIKO
PPM version: V 08.30
03-07-08
RM-240
(c) Nokia
E
BT MCM version: 2222-143
Retu version: 15
Tahvo version: 22
Content Pack version: Content: e
V 08.30
03-07-08
RM-240
(c) Nokia
Production serial number: CZA393290
Product code: 0543754
Module code: 0203327
Basic production code: 0543753
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 3530770283xxxx3 (edited)
IMEI spare to net: 3A 35 70 07 82 93 96 09
IMEI SV to net: 33 35 70 07 82 93 96 59 F1
LOCK STATUS:
PROVIDER KEY: 0000000000000000
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
WBR
ReyTech.
Old 01-21-2009, 13:06   #2 (permalink)
Member: 403264
Thanks Meter: 2
Try to use X-SIM or some other card that is used in using locked phone with any SIM. Other and only solution is RPL.
Old 03-19-2009, 19:38   #3 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 133
unlock with,
but u will have problem phone switching off after 10 mins or so.
Old 03-19-2009, 21:26   #4 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,656
batter way use ask to rpl service !!!
Old 03-19-2009, 22:36   #5 (permalink)
Super Moderator
Braycel's Avatar
Member: 813309
Sonork: (Off Line)
Thanks Meter: 1,826
repair rpl 100% tested brother
Old 03-19-2009, 23:53   #6 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
i think bb5+ cant succes rp provider with any unlocker until now
only new rpl file cane slove ur problem as i think
Old 03-20-2009, 00:07   #7 (permalink)
Member: 137237
yes only rpl help
Old 03-20-2009, 08:02   #8 (permalink)
Member: 175273
Thanks Meter: 65
but the rpl service is not working
Old 03-20-2009, 09:17   #9 (permalink)
Member: 728777
Thanks Meter: 11
try to repair sl security hopefully recover good luck
CONFIG KEY: 0000000000000000 is there any way to repair this! ATSC L.L.C J.A.F. By Jafsupport.com 0 01-21-2009 13:04
Is there any way to repair imei on M6100? Burnt Cobba VygisToolbox 3 11-25-2007 20:28
Damaged solder pads ? Is there any way to repair them ? simbirley Nokia Hardware & Hardware Repair 3 01-21-2003 19:27
Is there any way to repair "Contact Service" Using Dejan Flasher.? AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 04-26-2001 03:41
Is there any way to repair "Contact Service" Using Dejan Flasher AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-19-2001 22:08
Page generated in 0.31953 seconds with 8 queries
