Universalbox Universalbox Official support area |
03-17-2007, 19:26 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Denmark
Member: 64783 Status: Offline Thanks Meter: 5 | Confirmed: Server working! Dead K790i now alive and unlocked :) Just now.. back from the DEAD. Everything worked perfectly! |
The Following User Says Thank You to -Wickings- For This Useful Post: |
03-17-2007, 19:32 | #2 (permalink) |
Member: 64783 Status: Offline Thanks Meter: 5 | TUMTSUnlockPhoneThread started at: 2007-03-17 19:19:55 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Connecting to server: EU Asking service availability... Output power at Line1 4,20V is in range of: 4,00V ±10,0% Output power at Line2 4,80V is in range of: 5,00V ±25,0% Please turn on the phone! Serial line 1 speed changed to 460kBaud. Trying to send loader... OTP IMEI/CID/PAF: 3xxxx6-01-5xxxx2-X / 49 / 1 Output power at Line1 4,20V is in range of: 4,00V ±10,0% Output power at Line2 4,78V is in range of: 5,00V ±25,0% Please turn on the phone! Serial line 1 speed changed to 460kBaud. OTP IMEI/CID/PAF: 3xxxx6-01-5xxxx2-X / 49 / 1 First FlashID: 2019 ST patch loader sent Phone Color: RED. Phone CID: 51. Leaving test mode... Output power at Line1 4,20V is in range of: 4,00V ±10,0% Output power at Line2 4,78V is in range of: 5,00V ±25,0% Serial line 1 speed changed to 460kBaud. Entering explorer mode... OTP IMEI/CID/PAF: 3xxxx6-01-5xxxx2-X / 49 / 1 Initializing GDFS... Connecting to server: EU Bypassing security... Credits: xxxxx Credits left: xxxxx Connecting to server: EU Credits: xxxxx Credits Left: xxxxx Sign file saved. SIMLock signed succesfully. Leaving test mode... Please turn on the phone, and connect it to the DCU-60 cable Port found at: Sony Ericsson Device 049 USB WMC Device Management Connecting to server: EU Credits: xxxxx Credits left: xxxxx DCRCs calculated successfully. Waiting the phone to turn off... -------------------------------------------------------------------------------- TUMTSUnlockPhoneThread finished at: 2007-03-17 19:26:32 Done. Last edited by -Wickings-; 03-17-2007 at 19:42. |
03-17-2007, 19:44 | #6 (permalink) |
Member: 64783 Status: Offline Thanks Meter: 5 | Used FBUS. Select model, press Unlock. When it comes and tells you simlock already signed you have to press NO like it says (if it cant turn on). Then it says if you want to use old data, press NO again and it will take credits to calc. new. Then it can turn on and the last steps can be completed with DCU60. |
Setool server working again from now | Jr Telecom | SETool2 | 0 | 04-05-2009 21:34 |
SONYERICSSON P910i DEAD AFTER RSA REMOVAL AND UNLOCKING | toptech | HWK | 5 | 11-13-2008 09:39 |
E90 was Dead.. Now alive but problems | htcode | MT-BOX | 4 | 08-16-2008 07:19 |
Dead SCRD2 is now fixed and alive...very strange! | 07heaven | SagMaster Team OLD Products | 0 | 01-11-2006 19:52 |
Any working link for SPV firmware and unlock info? | SVH | Various | 8 | 08-09-2004 04:18 |
