dead k750 after reading info!!!!!!help!!! hi i used to read info of sonyEricsson k750 with universal box. ============================================== UMTSReadInfoThread started at: 2008/08/14 15:15:42 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3.93V is in range of: 4.00V ±10.0% Output power at Line2 6.22V is in range of: 5.00V ±25.0% Please turn on the phone! Serial line 1 speed changed to 460kBaud. Trying to send loader... OTP IMEI/CID/PAF: 355706-01-223405-X / 49 / 1 First FlashID: 890D Phone Color: RED. Phone CID: 49. PLEASE REMOVE, AND ATTACH THE BATTERY AGAIN! Output power at Line1 3.93V is in range of: 4.00V ±10.0% Output power at Line2 4.95V is in range of: 5.00V ±25.0% Please turn on the phone! Aborting process... ========================================= in the last level i removed and attached the battery again but phon doesent power on again . i tried so much.but no responce and i abort the operation. phone is dead now!! what shall i do? i need an emergency help.!:confused: regards |
Please Check Battery .its fully charged or not and if still same then need to Flash with latest firmware .i Hope your problem will be fine Regards F@iSaL |
all done thanks alot man.its alive again. |
