Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 11-25-2006, 09:39   #1 (permalink)
taihv's Avatar
Member: 40808
Dead N73, need urgent help!
First, i flash it with the same version with mcu+ppm, no cnt, all OK. Then i flash it again with ppm only, the same ver ofcourse, but after flashing it can't set default!! Try to turn phone on but it show only NOKIA and light flashing 2 times then off.
I flashing it again with mcu+ppm+cnt but still the same! Try again with all boxs i have, UB - JAF - MTbox - UFSHWK, and with the newest version 3.0638.0.0.30 but still no change!
Phone was working fine before, i just want to make a test! Original ver is 2.0628.0.0.1 EMEA.
Now when try to power on it only show NOKIA then the light flashing 2 times and goes off!
Any solution pls?
B.R.
Old 11-25-2006, 11:21   #2 (permalink)
fonec's Avatar
Member: 11101
Sonork: 100.1605000
make erase flash and flash it agin
erase flash way
u put file in mcu+ppm and flash it
and try flash agin
Old 11-25-2006, 13:42   #3 (permalink)
alex12345's Avatar
Member: 152573
Any solution pls?
B.R.
hi mate, modify ur n73 cable , coz it cant full factory reset.. after full factory reset ur phone will ok.
REgards
alex
Old 11-26-2006, 02:36   #4 (permalink)
taihv's Avatar
Member: 40808
REgards
alex
Thank for ur answer! But my cable is good, as i said, with the first time when i make flashing with mcu+ppm, all is OK, default set! But the pb happen at the second time when i try flashing only ppm!
erase flash way
and try flash agin
Thanks! I will try and put result here! But where i can find the erase file, or can i use this file from JAF support: erase_rap_adl_loader_modatty_by_tkr.fps8???
B.R.
Old 11-26-2006, 03:45   #5 (permalink)
alex12345's Avatar
Member: 152573
hi mate, try to flash back the ppm language b4 u change and post the result. can ur phone work on local mode??
Regards
alex
Old 11-26-2006, 04:14   #6 (permalink)
taihv's Avatar
Member: 40808
Thanks for ur reply!
I was NOT change lang pack! I ONLY test for flashing ppm!
And now, after flashing with the highest ver i have no way to back!
Phone can not goto test mode or local mode!
Cable is right, with R1=68K and R2=6.8k.
Try also with erase_rap_adl_loader_modatty_by_tkr.fps8, no change!
B.R.
P/S: Here the log:
MCU Nokia Version: 1.122, and up to date.
SMCU Nokia Version: 1.42, and up to date.
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: N73_3.0638.0.0.30_western_C00_PRD_cc.fpsx 44 980 kB
Speed: [51k, 6500k, 6500k, 98k] Baud.
Supported Hardwares: [0103192101003000, 010C192101003000]
Supported APE Hardwares: [17100708]
Input power: 14.10V OK.
Output power at Line1 4.24V is in range of: 4.00V ±10.0%
Boot Loader: RAP3Gv3_2nd.fg 15 kB
Version: 1.12.2
Supported Hardwares: [0103192101001101, 010C192101001101, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
Max Flash Devices: 1
Flash ID 1: 00EC22E8 - 0000 Rev: 6921 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000
Signature: 00000000000000000000000000000000
Flash Loader: RAP3Gv3_algo_fps8.fg 63 kB
Version: 1.12.2
Supported Hardwares: [0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
APE Boot Loader: helen3_2nd.fg 13 kB
Version: 1.28.0
Supported APE Hardwares: [17100700, 17100701, 17100702, 17100703, 17100704, 17100708]
Flash ID 1: 00EC00A1 - 0080 Rev: 0015 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000
Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
APE Flash Loader: h3_sam_nand_xsr.fg 63 kB
Version: 1.29.0
APE Asic ID: 17100708
APE Asic Mode ID: 00
APE Public ID: E4E162C08CDE8DEC6D7EC853C352FE7973107E70
APE Hash: 49A97E826B93BA20B7ED0B082475C00500000000
APE ROM ID: 1DFD66132C872FD4
Asic ID: 000000010000022600010006010C192101003000
EM Asic ID: 00000295
EM Asic ID: 00000B21
Public ID: 07E00116FDBB0054217ECB13D4DE57468537761D
Asic Mode ID: 00
Hash: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecHash: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
APE SecHash: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Erase time: 1:01,3 sec.
Writing flash...
After MCU Flash Delay: 5000 msec.
Flashing file:
BB5 [BB5 ALGORITHM] UCP File: N73_userarea_3.0638.0.0.30.U01 12 371 kB
Speed: [650k, 6500k, 6500k, 100k] Baud.
Supported Hardwares: [0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000]
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 9,3 sec.
Writing flash...
Flashing file:
BB5 [BB5 ALGORITHM] PPM File: N73_rofx_3.0638.0.0.30_PRD.V01 15 805 kB
Supported APE Hardwares: [17100700, 17100701, 17100702, 17100708]
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 5,8 sec.
Writing flash...
Total time: 12:30,8 sec.
After Flash Delay: 15000 msec.
Initializing phone...
TBB5FlashPhoneThread finished at: 2006/11/26 11:30:43
Terminated with error: 00010071. 00015018. 00011910
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->Universal Box [UBNUWBRD]
Old 11-26-2006, 07:32   #7 (permalink)
alex12345's Avatar
Member: 152573
B.R.
P/S: Here the log:
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
hi mate but ub log show cant enter local mode to do full factory reset. b4 u flash higher version, it can do full factory reset using same cable?
Regards
alex
Old 11-26-2006, 07:52   #8 (permalink)
taihv's Avatar
Member: 40808
I use the same cable!
This is my first log when i flashing with mcu+ppm:
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: scarfe_2.0628.0.0.3_western_C00_PRD_cc.fpsx 44 745 kB
Input power: 12.99V OK.
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 1:01,4 sec.
Writing flash...
Flashing file:
BB5 [BB5 ALGORITHM] PPM File: scarfe_rofx_2.0628.0.0.3_PRD.V01 13 154 kB
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 3,2 sec.
Writing flash...
Total time: 9:27,8 sec.
Set Defaults Timeout: 250 sec.
Setting defaults (it can take a minunte, or more)...
Set defaults time: 1,4 sec.
TBB5FlashPhoneThread finished at: 2006/11/24 13:19:14
Done.
And here, when i flashing only ppm, after few minutes later!
Flashing file:
Input power: 13.47V OK.
Output power at Line1 4.22V is in range of: 4.00V ±10.0%
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 3,5 sec.
Writing flash...
Total time: 2:49,4 sec.
TBB5FlashPhoneThread finished at: 2006/11/24 13:40:58
Old 11-26-2006, 10:49   #9 (permalink)
alex12345's Avatar
Member: 152573
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Done.
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
hi mate, u try flash version 3.0638.0.0.30 full flash?? mcu+ppm? try and post the log again
Old 11-26-2006, 10:58   #10 (permalink)
GUDO-GSM's Avatar
Member: 216769
Sonork: 100.1576865
try dead usb cable sir...
Old 11-26-2006, 11:06   #11 (permalink)
taihv's Avatar
Member: 40808
N73 not supportted for dead usb flashing yet!
Here you are, sir!
Flashing file:
Input power: 14.27V OK.
Output power at Line1 4.26V is in range of: 4.00V ±10.0%
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 53,10 sec.
Writing flash...
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Erase time: 2,10 sec.
Writing flash...
Total time: 10:34,2 sec.
TBB5FlashPhoneThread finished at: 2006/11/25 15:46:39
Old 11-26-2006, 13:30   #12 (permalink)
alex12345's Avatar
Member: 152573
Here you are, sir!
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
hi mate, have u try flash other n73 with this cable or try change cable..
this log show phone cant enter local mode to do full facotry reset. if cable u use try on other phone ok mean maybe hw problem. coz for me i got this kind of problem on my nokia 6280 b4, i modify my nokia 6280 cable b4 and can do full factory reset but somehow it spoilt itself and i try modify small ic on other cable and phone alive.
Regards
alex
Old 11-26-2006, 13:42   #13 (permalink)
GUDO-GSM's Avatar
Member: 216769
Sonork: 100.1576865
sorry for post...sir try to flash jaf use ufsbox insert dongle for jaf..use fbus cable sir n73...do it for flash sir..did ur try dongle jaf and ufsbox sir?
Old 11-26-2006, 17:52   #14 (permalink)
EIGY's Avatar
Member: 68075
B.R.
Hello! Ma8!
Before, What is problem N73?
BB5 DEAD USB Flashing Only S40,
Can not be S60 now!
Here you are, sir!
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Flashing file:
Version: 1.12.2
Version: 1.12.2
Version: 1.28.0
Version: 1.29.0
Asic Mode ID: 00
Writing flash...
Hello! Ma8!
You try this one!
Do not use erese file.
Then normal Flashing.
Pls yous Attach Pics.
And
Why??? input power 14.27?
Pls set up max 12V.
B.R.
EIGY.
Old 11-26-2006, 19:20   #15 (permalink)
fonec's Avatar
Member: 11101
Sonork: 100.1605000
sir can use anther computer
Dead N73 - Need help flashing Booji Nokia Base Band 5 ( BB-5 ) 8 11-01-2008 13:03
Dead N73 Not Flashing Help Urgent! Shayesta197 MT-BOX 4 11-11-2007 13:56
A300 working but after flash Dead. i need urgent help please. DrMobile VLSI, Conexant, Skyworks and Old Models 6 06-23-2004 11:09
Page generated in 0.69019 seconds with 12 queries
