Universalbox Universalbox Official support area |
06-01-2008, 00:04 | #1 (permalink) |
Junior Member Join Date: May 2005 Age: 43
Member: 149549 Status: Offline Thanks Meter: 0 | help 6131 dead by flash od 5200 him volvi to happen to the 6131 its original flash and does not accept please help |
06-01-2008, 00:23 | #2 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Hello Do a FULL ERASE of your phone ; Flash again with good flash files ; Write a good PM ; Order for a RPL file and write it to it BR Max_B |
06-03-2008, 20:53 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | for eraser- you need file for it you serch "eraser for rap" or is posible that you have it file in folder of 6131. well you need flash with it file your phone. after it you need flash with high version your phone. after it you need pm file and write it you can doing it in main, in bb5 section ( you need download a pm good) is posible that you have it file too in your pc in 6131 folder. after it you can see that you phone have imei 1234567890123? for resolver it you need write rpl for it you need logs and for it you need read post over it for more information over it. good luck. |
06-03-2008, 21:40 | #7 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | ok in first step full flash with highest version(V 6.60)[mcusw+ppm+ucp] if your phone dosnt alive yet,erase and then full flash with good flash file and then save ask file or use any rpl service same as uni and then write a good pm with pm auth service. |
6131 dead by over voltage | Mind Power | Nokia Hardware & Hardware Repair | 2 | 11-23-2009 03:50 |
6131 dead for flash 5200 | u649 | Universalbox | 0 | 05-30-2008 18:44 |
vahid i need the help/ j600 dead by flashing | BESTUNLOCKER | UST Pro II | 3 | 01-24-2008 20:49 |
6131 dead by phoenix!!! | luigivsf | Nokia Base Band 5 ( BB-5 ) | 2 | 08-20-2006 05:17 |
