Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 10-09-2006, 14:54   #1 (permalink)
Member: 352342
help me!?my box can't flash 7260 3220 6020!!
I have bought my universal-box about one month.I usually found my box flashed NOKIA 7260 3220 6020 which use 7260 cable getting wrong.The box said "Not available bootloader for this ID".I don't konw why.My 7260 cable is OK,because I have two cables.Both of the results are the same.Please tell me the problem of my box.My box flashes N70,6680,3230 OK.
Thanks!
Best regards!
FROM CHINA HUBEI WUHAN
Old 10-09-2006, 15:12   #2 (permalink)
Member: 248086
Thanks Meter: 22
sir check the cable... maybe the cable is damage.. try another cable...
Old 10-09-2006, 22:02   #3 (permalink)
Member: 80933
My friend use update tab this will download all FIA files you need for flashing.
Old 10-11-2006, 13:58   #4 (permalink)
Member: 352342
What's the FIA files?My cables are OK.Because I flash 7260 with this cable in UFS-3 well.
thanks
Best regards
China Hubei Wuhan
Old 10-11-2006, 13:59   #5 (permalink)
Member: 352342
thanks
Best regards
China Hubei Wuhan
Old 10-11-2006, 16:47   #6 (permalink)
Member: 80933
thanks
Best regards
China Hubei Wuhan
Simple open software go to update, then self update card then click on update button, your compute should be connected on internet - no firewall
BTW Fia is loader for phone located in phoenix folder.
Old 10-13-2006, 14:45   #7 (permalink)
Member: 352342
I update my UB on everyday morning.I usually connect APAC,but it always get wrong when it updates.It says "can't connect with service.So I can't download anymore from UB online service.The APAC network service is too bad.I hope it can be quick.
BEST REGARDS!
THANKS!
from China Hubei Wuhan
Old 10-14-2006, 01:33   #8 (permalink)
dr.danielman's Avatar
Member: 356508
Thanks Meter: 132
same problem
i can't flash 6020 7260 with ubox and with ufs 3 same cable same FIA work fine
best regads
Old 10-14-2006, 11:30   #9 (permalink)
Registered User
Member: 59722
your problem is only cable!! because i have 3 cable for 3230, 2 of them flash with ufs3 but by UB have err and another one with 2 boxes works good.
Pls help me!MY universalbox can't work!!!! zhangheng Universalbox 2 07-19-2008 09:14
Pls Help Me My Box Is Dead - solved sarfraz Multi-Box 7 05-25-2006 17:49
pls help me my box error wichaigul Universalbox 2 02-27-2006 14:21
Page generated in 0.22593 seconds with 9 queries
