Universalbox Universalbox Official support area |
11-12-2009, 15:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | How to repair watchdog problem with UB? After upgrading phone again, it now restarts every few minutes (Watchdog problem). I tried to "Restore certificates", but in the end it says "Failed to write PM block: 308, try use PM auth". Phone still has WD problem - but SIMlocks are OK so i don't think the 308 failure is a problem. Does anyone know how i can fix this phone? Is it possible to convert the "Read certs" backup to RPL file? Here's log from certificate restore: Code: TBB5RestoreCertThread 2.8.1.2191 started at: 2009.11.12 15:17:13 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 4,68V OK. Output power at Line1 3,93V is in range of: 4,00V ±10,0% Asic ID: 000000010000022600010006400C192101031103 EM Asic ID: 00000295 EM Asic ID: 00000B22 Public ID: 06A00008AD218B52C9BFB34538D8A8F2A54EEAC1 Asic Mode ID: 00 Hash: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Restoring certificates... CMT.NPC section parsed CMT.VARIANT section not found CMT.CCC section parsed CMT.HWC section parsed CMT.RnD section parsed CMT.SIMLOCK section parsed CMT.SIMLOCK_KEY section not found CMT.SUPERDONGLE_KEY section not found CMT.CMLA_KEY section not found CMT.WMDRM_PD section not found APE.NPC section not found APE.VARIANT section not found APE.CCC section not found APE.HWC section not found APE.RnD section not found Power off mode set. Flashing file: BB5 [BB5 ALGORITHM] MCU File: RPL 2 kB Speed: [3000k, 3250k, 3250k, 98k] Baud. Supported Hardwares: [400C192101031103] Input power: 4,72V OK. Output power at Line1 3,93V is in range of: 4,00V ±10,0% Boot Loader: RAPIDOv11_2nd.fg 15 kB Version: 1.30.0 Supported Hardwares: [0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105] Max Flash Devices: 2 Flash ID 1: 00EC0040 - 0040 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x020000 Flash ID 2: FFFF0000 - 0000 Rev: 0000 Manufacturer: Unknown MSB: 00 SectorSize: 0x020000 Signature: 00000000000000000000000000000000 Flash Loader: RAPIDOv11_algo.fg 186 kB Version: 1.31.0 Supported Hardwares: [0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105] Using RX2 flash. Asic ID: 000000010000022600010006400C192101031103 EM Asic ID: 00000295 EM Asic ID: 00000B22 Public ID: 06A00008AD218B52C9BFB34538D8A8F2A54EEAC1 Asic Mode ID: 00 Hash: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecHash: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Writing flash... Flashing section: [00] NPC Flashing section: [00] CCC Flashing section: [00] HWC Flashing section: [00] R&D After MCU Flash Delay: 5000 msec. Total time: 22,1 sec. Output power at Line1 3,93V is in range of: 4,00V ±10,0% Auto power-on mode set. Initializing phone... Output power at Line1 3,93V is in range of: 4,00V ±10,0% Phone powered. PRODUCTCODE set PSN set HWID set Reading Info... Soft Version: V ICPR72_09w20.8 Date: 09-07-09 Type: RM-356 (5800D-1 XPRESS MUSIC) Pack: (c) Nokia Product code: 0579555 Product code: 0584666 WLAN MAC: 9C187495B368 Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA VIII Original IMEI: 357988-03-******** Production serial: MIK016583 HW Version: 1102 DSP Version: ICPR72_09w19_1 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000B09031F] Profile bits: 0000000000000000 Simlock config: 2440700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Open; Data: FFFFFF Block: 2; Lock: 1; State: Open; Data: FFFFFF Block: 3; Lock: 1; State: Open; Data: FFFFFF Block: 4; Lock: 1; State: Open; Data: FFFFFF Block: 5; Lock: 1; State: Open; Data: FFFFFF Block: 6; Lock: 1; State: Open; Data: FFFFFF Block: 7; Lock: 1; State: Open; Data: FFFFFF All locks are open. Restoring security field... Writing PM values... Failed to write PM block: 308, try use PM auth -------------------------------------------------------------------------------- TBB5RestoreCertThread 2.8.1.2191 finished at: 2009.11.12 15:18:42 Done. |
11-16-2009, 08:48 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | that's way you've face like that problem "Called Watch Dog" i think you don't know right now not posible to downgrade V3.xx to 2.xx or down, anyway kindly again flash with Original Firmware (V3.XX) then restore cert hope your problem will be solve |
11-16-2009, 11:35 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Man you can't repair watch dog timer of n96,5800........etc with any device because their pm field (120) & (308) both are right protected you can't over write them only full rpl is the solution no skip mode will work in this condition Thanks Bro S@m |
11-17-2009, 13:11 | #7 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Here Age: 47
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | Quote:
How to get a RPL file? Any server are working, or maybe a box? | |
How to repair watchdog timer on 6310i | corvinu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 11-09-2018 00:48 |
How to repair Chinese phones with problems like "not power on/reboot/restart.. etc" | GSMtricks | Chinese Cocktail | 37 | 11-15-2012 05:23 |
How to repair gdfs problem P990i using UB? | kungpaoski | Universalbox | 3 | 10-27-2009 10:17 |
How to repair Chinese phones with problems like "not power on/reboot/restart.. etc | GSMtricks | PadFinder box | 3 | 09-03-2008 08:10 |
how to repair k700 hang with ub? | ardanzx | Universalbox | 15 | 10-10-2007 14:50 |
