Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 12-21-2009, 13:29   #1 (permalink)
X-TRA's Avatar
Member: 303790
how restore the backup on sl2
i have 3120 which i do the flash on it and tries with erase and many more thing now the sets imei is cruppted 12345 and i already was takes its back up before so how to i restore again it
Old 12-21-2009, 16:15   #2 (permalink)
X-TRA's Avatar
Member: 303790
here is log status of ma set
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing phone...
Output power at Line1 3.93V is in range of: 4.00V ±10.0%
Phone powered.
Reading Info...
Soft Version: V 09.41 Date: 06-11-08 Type: RM-364 (3120C-1C) Pack: (c) Nokia
Product code: 0560876
Product code: 0553930
Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA II / WCDMA V / WCDMA VIII
Original IMEI: 123456-10-********
Production serial: DEJ358198
HW Version: 1000
DSP Version: ICPR71_08w30
LCD Version: SEIKO
APE ADSP Version:
SIMLock service: SIMLOCK SERVER [01000407031E]
Simlock info invalid
Reading PM...
Superdongle data exists
TBB5CheckSDThread 2.8.4.2505 finished at: 2009/12/21 21:14:09
Done.
Old 12-21-2009, 16:19   #3 (permalink)
X-TRA's Avatar
Member: 303790
here when i restore certificate
Input power: 4.82V OK.
Asic ID: 000000010000022600010006010C192101003000
EM Asic ID: 00000295
EM Asic ID: 00000B22
Public ID: 1170020C01B67C567786A0D465FAF7B0DC4BA864
Asic Mode ID: 00
Hash: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
Restoring certificates...
CMT.NPC section parsed
CMT.VARIANT section not found
CMT.CCC section parsed
CMT.HWC section parsed
CMT.RnD section parsed
CMT.SIMLOCK section parsed
CMT.SIMLOCK_KEY section parsed
CMT.SUPERDONGLE_KEY section not found
CMT.CMLA_KEY section not found
CMT.WMDRM_PD section not found
APE.NPC section not found
APE.VARIANT section not found
APE.CCC section not found
APE.HWC section not found
APE.RnD section not found
Power off mode set.
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: RPL 25 kB
Speed: [3000k, 3250k, 3250k, 98k] Baud.
Supported Hardwares: [010C192101003000]
Boot Loader: RAP3Gv3_2nd.fg 15 kB
Version: 1.30.0
Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
Max Flash Devices: 2
Flash ID 1: 0001003F - 0000 Rev: 8A21 Manufacturer: AMD MSB: 00 SectorSize: 0x020000
Flash ID 2: FFFF0000 - 0000 Rev: 0000 Manufacturer: Unknown MSB: 00 SectorSize: 0x020000
Signature: 00000000000000000000000000000000
Flash Loader: RAP3Gv3_algo.fg 166 kB
Version: 1.31.0
Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
Using RX2 flash.
Asic Mode ID: 00
SecHash: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79
Writing flash...
Flashing section: [00] NPC
Flashing section: [00] CCC
Flashing section: [00] HWC
Flashing section: [00] R&D
After MCU Flash Delay: 5000 msec.
Total time: 17,6 sec.
Auto power-on mode set.
Phone powered.
PRODUCTCODE set
PSN set
HWID set
SIMLOCK section write failed! [0x0007]
Reading Info...
Product code: 0561596
Production serial: KCU500160
HW Version: 2002
LCD Version: SEIKO
APE ADSP Version:
Backup security file C:\uni\Files\Nokia\BB5\BACKUP\12345610654321?_BACK UP.PM not found
TBB5RestoreCertThread 2.8.4.2505 finished at: 2009/12/21 21:17:46
Done.
but the fact is that i have save the cert backup in c drive uni files bb5 back up folder so where is the problem
Old 12-21-2009, 16:27   #4 (permalink)
Member: 87357
Sonork: 100.1574043
there is no any problem because Backup is not Saved
Old 12-21-2009, 16:29   #5 (permalink)
X-TRA's Avatar
Member: 303790
this is back and its already saved
how to write on that i cant understand
Old 12-21-2009, 16:32   #6 (permalink)
Member: 87357
Sonork: 100.1574043
Just Write This Backup PM File and Post here Reuslt,
Old 12-21-2009, 16:36   #7 (permalink)
X-TRA's Avatar
Member: 303790
yes i wrote many time but the results are
every time
i dont know where i save it that the software say me yes its done
Old 12-21-2009, 16:51   #8 (permalink)
X-TRA's Avatar
Member: 303790
here is result
TBB5PMAuthThread 2.8.4.2505 finished at: 2009/12/21 21:48:50
Aborted by user.
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->Universal Box [UBSCL5UF]
TNokiaWritePMThread 2.8.4.2505 started at: 2009/12/21 21:48:51
Phone powered.
Writing PM values...
TNokiaWritePMThread 2.8.4.2505 finished at: 2009/12/21 21:49:43
Done.
TBB5ReadInfoThread 2.8.4.2505 started at: 2009/12/21 21:49:45
Reading Info...
Product code: 0559069
Product code:
Production serial: 0
HW Version:
LCD Version: SEIKO
APE ADSP Version:
TBB5ReadInfoThread 2.8.4.2505 finished at: 2009/12/21 21:49:49
Done.
Old 12-24-2009, 11:41   #9 (permalink)
Member: 87357
Sonork: 100.1574043
123456-10-********
You Won't be Solve this Problem By UB , you will need bb5 Rpl Service to Solve this issue,
Old 12-24-2009, 12:06   #10 (permalink)
X-TRA's Avatar
Member: 303790
dear why purchase new 1 rpl for it infect before i erase the flash file i restore its pm and also cert and its because of ub so ma question is why i can not solve this set with ub
Old 12-25-2009, 01:46   #11 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Hello
354849027834243_BACKUP.rar
its simlock backup [120] [308], if you need to restore or if you face problem by restore button,
just click write pm button or select 354849027834243_BACKUP.PM for restore simlocks
about imei (rpl cert) you need to check again backup folder (if you have saved before start operation then you able to restore)
Old 12-26-2009, 15:30   #12 (permalink)
Member: 1191357
Sonork: o
Aduh sulit ya kalau tidak bisa bahasa ingris
tapi sedikit" ngerti juga heee
Old 12-26-2009, 17:01   #13 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
only post ur message in english
see fourm rules
br
How about the Explanation On Huawei Nck Calculation? eyestrain GSM Programming & Reverse Engineering 3 03-22-2010 08:43
Er2 when trying to restore backup... Can I use Backup on other tools?? Crazy_ratata Genie Universal 0 07-29-2009 20:25
restore backup on bg its on off jaaja BF, BG, TH, BHx Series 0 03-01-2005 17:43
how to make backup on the 8310? hooi76 Nokia Digital Core Technology 4 ( DCT-4 ) 13 10-25-2002 04:21
How read the languages on Alcatel View BE3? -=G3=- Alcatel & TCL Old Models 1 01-29-2002 19:37
Page generated in 0.62577 seconds with 12 queries
