Imei Repair Slution For Hardware Engineers HI with ub we can repair imei with some hardware work without new uem uem is a otp (one time program) device take a old pcb if connect with software (for example if uem imei is good) then read or save rpl of uem from old pcb change a uem in another bord and write rpl(wich rpl you have save befor) of this uem this procedure will repair imei of ur mobile without changing of new uem (1)old uem must be ok (2) save old uem rpl from its orignal bord (3) write old uem rpl after replace on a bord b/r IKHLAQ |
Hardware HI in this case if anyone wants to chang flash ic then only chang flash ic then write full flash it then write rpl b/r IKHLAQ |
If the asic of both phone are the same ... The RPL from an asic2 phone doesn't work on a phone with asic6 3220 and 6230 for example ... |
Brother thanx for your solution ! But we are already doing it from long long time :D Regards, Tanvir ! www.tanuelectronics.com |
Hardware HI well if you know befor. but i would like to inform other member of forum b/r IKHLAQ |
Read the post very carefully and don't talk just for the sake of talking ... |
You are joking! :D :D :D :D :D best regards! |
