Universalbox Universalbox Official support area |
11-05-2008, 02:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: service bob
Member: 761534 Status: Offline Thanks Meter: 9 | ***k310i error java maintenance*** Dear Users UB, I could not unlonck K310i, for an error, which is the solution to this error, I am doing wrong or that I need to install? TUMTSJavaUnlockPhoneThread started at: 2008/11/04 18:15:14 -------------------------------------------------------------------------------- MCU Ericsson Version: 1.262, and up to date. SMCU Ericsson Version: 1.62, and up to date. Output power at Line1 3.97V is in range of: 4.00V ±10.0% Output power at Line2 5.03V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Trying to send loader... OTP IMEI/CID/PAF: ****************** / 49 / 1 First FlashID: 897E Phone Color: RED. Phone CID: 49. Leaving test mode... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Output power at Line2 5.03V is in range of: 5.00V ±25.0% Serial line 1 speed changed to 920kBaud. Entering explorer mode... OTP IMEI/CID/PAF: ****************** / 49 / 1 Initializing GDFS... Soft version: R4DA044 prgCXC1250466_GENERIC_DO -------------------------------------------------------------------------------- TUMTSJavaUnlockPhoneThread finished at: 2008/11/04 18:15:54 Terminated with error: Rest file not found [00024D11] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQUNGGM] |
11-05-2008, 03:40 | #2 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Dear select your model * click simple unlock your phone sucsessfull unlock * & java can not support k310i CID49 |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
11-05-2008, 06:45 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Yeah one day i have tried to test patching mathod on k310 but failed like you. so its now free to unlock any phone just press unlock. |
The Following User Says Thank You to asadnow2k For This Useful Post: |
11-07-2008, 14:05 | #5 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | you can repair imei in ericsson mentance tab in imei change for more information watch http://forum.gsmhosting.com/vbb/showthread.php?t=513759 |
11-07-2008, 14:25 | #6 (permalink) |
Freak Poster Join Date: May 2005
Member: 147811 Status: Offline Thanks Meter: 27 | simply do this... (1) go to maintenance. (2) check patch software (3) uncheck use opt imei (4) write your imei in box (5) do jo b/r ikhlaq |
The Following User Says Thank You to ikhlaq For This Useful Post: |
Browser error and java app loader crashes - Help! | needhelp4a835 | Motorola P2k | 1 | 06-11-2004 07:25 |
M55 java error | Demonfi | Java, iOS, Android, Symbian development | 1 | 10-16-2003 12:17 |
Java error after using javaaktivator | prabbie | x1x to x45/x50 | 2 | 09-04-2003 22:24 |
S300 java install error? | ThrillSeeker | Trident/AGERE Platform | 3 | 08-05-2003 06:35 |
