K608i unlocked ok and then no power... hi all tried this K608i with CID 49. used test point (had some trouble to make test point since it was surrounded with epoxy glue). It was shown that phone colour was RED. (in fact this is silver from 3).. anyway..... Once cleared the locks , it was asked to repower again... phone then was detected as CID 16. and then test mode was disengaged (according to the log) Tried to power it up and no power. Tried to communicate again with phone it reacts ok but stops when sending boot loader. Is this a hardware or software problem pls? need some guidance asap pls. thanks for any help al |
Try Again Changing CID color to RED and Then Unlock If still not... Flash with k600 flash ........Hope It Works |
bR |
can i remove resistor compeltely and instead short the 2 points directly? i dont know the value of the resistor also :( i had problems since the area was imersed in epoxy glue. thanks for the help al |
you just need to short the TP to the ground only, after the phone is detected you must disconnect the TP. |
bR |
problem solved phewww as essojay suggested the resistor part had dislodged slightly from the track. had to connect the track and solder it back to the resistor section. If anyone has such a problem just plug in the charger. If the red light does not show up then the track has been damaged. thanks essojay al |
