Nokia 2700C After Nokia white display Is there any solution for Nokia2700c After Nokia white display ? |
Didi you Tried to Solve this issue by Flashing? |
I got above 1000 bb5 phone like this problem 85%this cause solved by flashing:d |
http://i49.tinypic.com/n54ihf.jpg http://i49.tinypic.com/n54ihf.jpg |
answer has in your screen shot, check battery or cable, then try again, |
oh ***, i've the same set with the same problem. tried changing usb and battery, still get the same error.... can easy flash it before update, but now just wun work. |
then try again post result |
TBB5USBFlashThread 2.8.8.2629 started at: 2010/06/02 17:36:55 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device --- Press phone's power button! --- Loading secondary boot code: 14464 bytes Secondary boot loaded Loading update server code: 248320 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Scanning image files... Using 128k file from rm146__07.20.image_ctv_my_128... Asic CMT: Start programming 25103 KB... Asic CMT: Erasing rm146__07.20.mcusw Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing area 6... Asic CMT: Erasing area 7... Asic CMT: Erasing area 8... Asic CMT: Erasing area 9... Asic CMT: Erasing rm146__07.20.ppm_s Asic CMT: Erasing area 1... Asic CMT: Erasing rm146__07.20.image_ctv_my_128 Asic CMT: Erasing area 1... Asic CMT: Programming rm146__07.20.mcusw ADL LDR: Error sending ADL_LDR_WRITE_DATA_REQ size 0xC000 ADL LDR: Error sending write message.... ADL LDR: Resending Prepare for Write Request.... ADL LDR: Resending Prepare for Write Request.... ADL LDR: Resending Prepare for Write Request.... ADL LDR: Resending Prepare for Write Request.... ADL LDR: Resending Prepare for Write Request.... ADL LDR: Resending Prepare for Write Request.... ADL LDR: Error writing to target address 0x0050C400, Size 0x0000C000 Asic CMT: ERROR Programming rm146__07.20.mcusw Block 221. Unable to continue flashing. Asic CMT: Error in sending data from rm146__07.20.mcusw. Protocol 1: Error during Flashing. Unable to continue. Unable to flash phone 0x84012283 -------------------------------------------------------------------------------- TBB5USBFlashThread 2.8.8.2629 finished at: 2010/06/02 17:39:55 |
Today i have same type of issue.. trying to flash with latest firmware.. and going to post results.. |
this is hardware fault 2700/5130/2690 etc |
