Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 05-31-2010, 15:58   #1 (permalink)
Member: 1315046
Thanks Meter: 36
Nokia 2700C After Nokia white display
Is there any solution for Nokia2700c After Nokia white display ?
Old 05-31-2010, 16:01   #2 (permalink)
Member: 87357
Thanks Meter: 9,457
Didi you Tried to Solve this issue by Flashing?
Old 06-01-2010, 08:26   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Originally Posted by masusa26 View Post
is there any solution for nokia2700c after nokia white display ?
brother flash it lastest version via usb
Originally Posted by babak nuri View Post
only hardware fault
clean board
bro,ru sure?
I got above 1000 bb5 phone like this problem 85%this cause solved by flashing:d
Old 06-01-2010, 08:37   #4 (permalink)
Member: 1315046
Thanks Meter: 36
bro,ru sure?
Bro i've tried it
http://i49.tinypic.com/n54ihf.jpg
Old 06-01-2010, 08:40   #5 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
answer has in your screen shot, check battery or cable, then try again,
The Following User Says Thank You to Ja\/\/aD For This Useful Post:
Old 06-01-2010, 11:53   #6 (permalink)
Member: 233092
oh ***, i've the same set with the same problem. tried changing usb and battery, still get the same error.... can easy flash it before update, but now just wun work.
Old 06-01-2010, 12:04   #7 (permalink)
Member: 351924
yes yes u must use fully charge batt
then try again
post result
Old 06-02-2010, 10:01   #8 (permalink)
Member: 1315046
Thanks Meter: 36
then try again
post result
I'm using fully charged Battery, but same problem
Old 06-02-2010, 12:47   #9 (permalink)
Member: 75876
Thanks Meter: 77
it happens to me 5300 usb flashing got same error. i tried other box 100% success.
Old 06-02-2010, 12:49   #10 (permalink)
Member: 75876
Thanks Meter: 77
TBB5USBFlashThread 2.8.8.2629 started at: 2010/06/02 17:36:55
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing flasher...
Initializing
Scanning image files...
Waiting for USB device...
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
--- Press phone's power button! ---
Loading secondary boot code: 14464 bytes
Secondary boot loaded
Loading update server code: 248320 bytes
Update server loaded
Asic CMT: Verifying communication to device...
Using 128k file from rm146__07.20.image_ctv_my_128...
Asic CMT: Start programming 25103 KB...
Asic CMT: Erasing rm146__07.20.mcusw
Asic CMT: Erasing area 1...
Asic CMT: Erasing area 2...
Asic CMT: Erasing area 3...
Asic CMT: Erasing area 4...
Asic CMT: Erasing area 5...
Asic CMT: Erasing area 6...
Asic CMT: Erasing area 7...
Asic CMT: Erasing area 8...
Asic CMT: Erasing area 9...
Asic CMT: Erasing rm146__07.20.ppm_s
Asic CMT: Erasing rm146__07.20.image_ctv_my_128
Asic CMT: Programming rm146__07.20.mcusw
ADL LDR: Error sending ADL_LDR_WRITE_DATA_REQ size 0xC000
ADL LDR: Error sending write message....
ADL LDR: Resending Prepare for Write Request....
ADL LDR: Error writing to target address 0x0050C400, Size 0x0000C000
Asic CMT: ERROR Programming rm146__07.20.mcusw Block 221. Unable to continue flashing.
Asic CMT: Error in sending data from rm146__07.20.mcusw.
Protocol 1: Error during Flashing. Unable to continue.
Unable to flash phone 0x84012283
TBB5USBFlashThread 2.8.8.2629 finished at: 2010/06/02 17:39:55
Old 08-08-2010, 09:08   #11 (permalink)
Member: 199814
Thanks Meter: 1,960
Today i have same type of issue.. trying to flash with latest firmware.. and going to post results..
Old 08-18-2011, 16:50   #12 (permalink)
Member: 840654
Thanks Meter: 19
this is hardware fault 2700/5130/2690 etc
Page generated in 0.25985 seconds with 9 queries
