Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 03-11-2009, 13:26   #1 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 177
Nokia 5310 xm show nokia logo and power off after flash????
i try to flash nokia 5310 xm with usb , select flash file dead usb and flash procces started but in the end not set factory dafaults and now phone start show only nokia logo and power off, how to solve this?
Old 03-11-2009, 13:43   #2 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 329
try flash latest version post result
Old 03-11-2009, 16:40   #3 (permalink)
Member: 199814
Thanks Meter: 1,960
Yeah BB5 should be flash always latest firmwares.. instead of downgrading
Old 03-11-2009, 17:05   #4 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 271
try with latest firmware and you should format file system 'file2',if phone is in local mode.you can use local mode adaptor for stable powering state,local mode or test mode with fbus cable.
Old 07-24-2009, 17:23   #5 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
Unhappy
i faced the same situation and tried to flash with latest versions.(9.45 and 10.10) and ufs and jaf but the problem could not solved.....i think it is hardware issue.........
The Following User Says Thank You to quasim0438 For This Useful Post:
Old 07-24-2009, 17:38   #6 (permalink)
Member: 761864
Thanks Meter: 63
you need to flash it with latest FW version... software 1st before hardware....
Old 07-24-2009, 17:50   #7 (permalink)
Maiwand khan's Avatar
Member: 295886
Sonork: 100.1583369
Thanks Meter: 1,472
flash ur phone with 10.10 version
i am sure ur problem will salove
Old 07-24-2009, 20:58   #8 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Thanks Meter: 21,659
without any log/screen not possible to find out exact problem so kindly post here log
V3t shows Motorla logo and power of enrocas Motorola P2k 6 10-12-2008 12:22
nokia 6600 hang and power-off after pincode off rovick Nokia Multimedia 3 08-04-2008 12:23
Nokia 6030 Signal drop and power off after few second Munir Memon Universalbox 3 07-21-2008 11:42
x300 logo come and goes off after flash gbada Infinity-Box 1 12-10-2005 21:45
8310 imei showing ?????????¤ and power off after few sec! Gsmhq Twisterflasher 3 11-03-2004 21:15
Page generated in 0.22131 seconds with 9 queries
