Nokia 6303 flash by dead usb but error, solve pls i have 6303 dead , flash by dead usb but error, solve pls Thx MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... Waiting for USB device... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Loading secondary boot code: 14592 bytes Error sending Secondary binary data to Boot Server, 0x84009427 -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2821 finished at: 2011/05/10 19:12:03 Terminated with error: Firmware: Firmware updating failed. Error 0x8401F16F - Flash: Failed to load secondary server [00010123] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->UniversalBox [UBFFW1QV] |
maybe hardware fault please check hardware |
same problem with same mobile any solution? Ist mobile was dead i tried flashing dead usb reaching 80% it gave me error and know can,t flash again its giving me same error 0x84009427 from start showing in this post |
Flashing it with FBUS may help but not using UB, else if still get error then its HW problem. |
Have you flash any other bb5 phone by dead usb flashing? |
yes i have flashed many phones via dead usb method . |
Since the last update i also can't flash any BB5 by dead USB. Find the problem please and fix it |
brother in your case its look like hard ware problem. |
Brother its software problem 1st software micro with skip erase then flash usb. 2 check usb conection I hope ur problem solved |
i have the same problem, a phone come to me working perfectly, the client want to change language, i think wrongly, flashing with another flash of the language he wants the work be done, but phone is dead, well now i m trying to flash with correct flash fiirmmware but i get the same MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing flasher... Initializing Scanning image files... 1. Make sure USB cable, Battery and charger are removed from device. 2. Insert USB cable to device 3. Insert Battery to device 4. Insert Charger to device Waiting for USB device... Loading secondary boot code: 14592 bytes Secondary boot loaded Loading update server code: 427648 bytes Update server loaded Error initializing Algorithm. 0x84009427 -------------------------------------------------------------------------------- TBB5USBFlashThread 2.9.3.2824 finished at: 2011/07/22 00:47:22 Terminated with error: Firmware: Firmware updating failed. Error 0x8401F167 - Flash: Failed to initialize update server [00010123] MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBTEST99] -------------------------------------------------------------------------------- TUniversalForm 2.9.3.2824 finished at: 2011/07/22 00:54:56 any solution i tried using usb dead fbus cales the hard was working perfectly before, please i need help |
my 6303 clasic camera nor working properly flash me |
