Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Universalbox
Universalbox Universalbox Official support area
Old 05-10-2011, 15:04   #1 (permalink)
Member: 1275426
Nokia 6303 flash by dead usb but error, solve pls
i have 6303 dead , flash by dead usb but error, solve pls Thx
MCU Nokia Version: 1.132, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Initializing flasher...
Initializing
Scanning image files...
Waiting for USB device...
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
Loading secondary boot code: 14592 bytes
Error sending Secondary binary data to Boot Server, 0x84009427
TBB5USBFlashThread 2.9.3.2821 finished at: 2011/05/10 19:12:03
Terminated with error: Firmware: Firmware updating failed. Error 0x8401F16F - Flash: Failed to load secondary server [00010123]
MCU Boot Version: 1.069, and up to date.
SMCU Boot Version: 1.34, and up to date.
Device opened at USB->UniversalBox [UBFFW1QV]
Old 05-10-2011, 15:20   #2 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
maybe hardware fault please check hardware
Old 05-30-2011, 16:26   #3 (permalink)
Mustansar's Avatar
Member: 1081067
same problem with same mobile any solution? Ist mobile was dead i tried flashing dead usb reaching 80% it gave me error and know can,t flash again its giving me same error 0x84009427 from start showing in this post
Old 05-30-2011, 18:54   #4 (permalink)
xerraco's Avatar
Member: 890926
Flashing it with FBUS may help but not using UB, else if still get error then its HW problem.
Old 05-31-2011, 07:16   #5 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
Have you flash any other bb5 phone by dead usb flashing?
Old 05-31-2011, 08:33   #6 (permalink)
sheraz_mobiles's Avatar
Member: 724090
Sonork: 100.1601663
Initializing
100% hardware.......................................... ...............
Old 05-31-2011, 12:37   #7 (permalink)
Mustansar's Avatar
Member: 1081067
yes i have flashed many phones via dead usb method .
Old 06-02-2011, 09:33   #8 (permalink)
Member: 607934
Since the last update i also can't flash any BB5 by dead USB. Find the problem please and fix it
Old 06-02-2011, 10:19   #9 (permalink)
abidfarooq's Avatar
Member: 102445
Sonork: 100.1603645
brother in your case its look like hard ware problem.
Old 06-02-2011, 12:01   #10 (permalink)
Ja\/\/aD's Avatar
Member: 80354
Sonork: 100.1577575
if you check sticky thread about successfully Flash you will how many phone dailly flashed by new updates, you need to check your phone or your pc setting, etc.
Old 06-02-2011, 18:43   #11 (permalink)
bobaly's Avatar
Member: 1291612
Sonork: 100.1625587
Brother its software problem
1st software micro with skip erase then flash usb.
2 check usb conection
I hope ur problem solved
Old 07-22-2011, 00:29   #12 (permalink)
Member: 1313139
Sonork: Ghost
i have the same problem, a phone come to me working perfectly, the client want to change language, i think wrongly, flashing with another flash of the language he wants the work be done, but phone is dead, well now i m trying to flash with correct flash fiirmmware but i get the same
Initializing
Secondary boot loaded
Loading update server code: 427648 bytes
Update server loaded
Error initializing Algorithm. 0x84009427
TBB5USBFlashThread 2.9.3.2824 finished at: 2011/07/22 00:47:22
Terminated with error: Firmware: Firmware updating failed. Error 0x8401F167 - Flash: Failed to initialize update server [00010123]
Device opened at USB->Universal Box [UBTEST99]
TUniversalForm 2.9.3.2824 finished at: 2011/07/22 00:54:56
any solution i tried using usb dead fbus cales the hard was working perfectly before, please i need help
Old 11-23-2011, 13:45   #13 (permalink)
Member: 1694477
Sonork: rakatamil143@ymail.com
my 6303 clasic camera nor working properly flash me
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.47192 seconds with 11 queries
