Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Universalbox
Universalbox Universalbox Official support area
Old 07-08-2006, 20:06   #1 (permalink)
Member: 177088
Thanks Meter: 15
Nokia N70 Flashing Error
Hi...I have a Nokia N70 with a white screen probelm which I am trying to flash. I have downloaded the flash file version 2.0539.1.2 which contains the product code for the phone. But when I select the product code it does not automatically load the mcu and ppm files so I manually select the file mcu file (2053912_RM84RD.V55) but I get this error
Terminated with error: 000100A6,000100AE,000100B8,0001107B etc
I have even tried a fllash file from version 5.0616.2.0.3 and don't select the product code as it's not listed there. I select the flash file RM84_50616203.CO but I still get the same error.
Can someone please help? Thanks
Old 07-09-2006, 18:09   #2 (permalink)
EIGY's Avatar
Member: 68075
Thanks Meter: 51
You try erase flah and Flash try again!
PS: Pls Buckup PM first!
B.R.
EIGY.
Old 07-09-2006, 18:28   #3 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
try to use other box, jaf will do.
Old 07-09-2006, 18:41   #4 (permalink)
Member: 65032
Thanks Meter: 5
other boxes
this is universalbox section, dnt tell others to try other boxes. we wnna knw the prob with this box not other boxes. and i do have other boxes, but i'm happy with this 1!!
Old 07-09-2006, 23:35   #5 (permalink)
Member: 177088
Thanks Meter: 15
I don't have jaf and I've spent enough money on the universal box so I would like to see universal box work rather than just try another solution each time uni box doesn't do the job.
We need to share solutions to make the uni box work for us all.
Old 07-09-2006, 23:41   #6 (permalink)
Member: 177088
Thanks Meter: 15
B.R.
EIGY.
I tried to erase the flash but I get the same terminated error message when trying to erase flash.
Old 07-10-2006, 03:14   #7 (permalink)
epic's Avatar
Member: 10635
Thanks Meter: 10
are you using 12V power adaptor?
BR,
epic
Old 07-10-2006, 09:52   #8 (permalink)
Member: 177088
Thanks Meter: 15
BR,
epic
I'm using the 2 pin power adaptor that came with the box.
Old 07-10-2006, 13:12   #9 (permalink)
EIGY's Avatar
Member: 68075
Thanks Meter: 51
Pls post log file here!
B.R.
EIGY.
Old 07-10-2006, 13:41   #10 (permalink)
universalbox's Avatar
Member: 68982
Thanks Meter: 17,853
The box cant select the correct files, if not all .ini file donloaded. Anyway, i think you downgraded your phone. Today we will start our US server, so who have good connection to USA, can download full sw version and then select the files from the dropdown menu. Use the latest file to repair your phone.
Old 07-10-2006, 13:54   #11 (permalink)
Member: 177088
Thanks Meter: 15
I downloaded the files again and this time when I select the product code the mcu and ppm files are selected but I still get the same terminated error message when I try to flash the phone or even when I tried to erase the flash.
I have successfully flashed another N70 the same way so I don't think that I am doing anything wrong.
Thanks.
Old 07-10-2006, 18:51   #12 (permalink)
Member: 177088
Thanks Meter: 15
B.R.
EIGY.
Please find attached screen print and log file. Thanks
Old 07-10-2006, 19:12   #13 (permalink)
Member: 65032
Thanks Meter: 5
n7o flashing
hi there! did u manage to flash your phone? i still get same error
Old 07-10-2006, 19:29   #14 (permalink)
EIGY's Avatar
Member: 68075
Thanks Meter: 51
Maybe problem Firmware virsion!
Pls! High or latest Flash files use then Flash!
PS:
I try BB5 Flshing allways this one!
With out Enable High Speed Flash.
Use 6.0V to 6.5V input power.
B.R.
EIGY.
Old 07-10-2006, 19:36   #15 (permalink)
Member: 177088
Thanks Meter: 15
PS:
B.R.
EIGY.
Hi...I am using the lastest firmware 5.0. and am using the power supply that came with the uni box. I will try without Enable High Speed Flash. Thanks
nokia N70 flash error.................. vertex777 J.A.F. By Jafsupport.com 0 12-17-2008 07:37
Page generated in 0.45243 seconds with 9 queries
