Universalbox Universalbox Official support area |
04-26-2008, 13:43 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: in the corner Age: 35
Member: 285779 Status: Offline Thanks Meter: 49 | plz take a look at my problem i install at notebook . the ub can open all the way . both compu also sp2 xp . guys plz share me if u have idea . thz * driver install prpperly |
04-26-2008, 15:08 | #2 (permalink) |
Freak Poster Join Date: Dec 2001 Location: InnovateK
Member: 8012 Status: Offline Thanks Meter: 124 | Check the lenght ( the shorter the better) and quality of the USB cable you use to connect the UB to PC, if itīs the same cable you use to connect the UB to Notebook and is ok, the problem must be in USB ports of your PC Motherboard that canīt delivery enough power . ( i guess you tried another ports in your PC and do the same, right) BR AC |
04-28-2008, 12:09 | #4 (permalink) |
Member: 8012 Status: Offline Thanks Meter: 124 | It can be one possible solution, but i guess the problem isnīt the PC power supply but the Motherboard itself. One possible cause is also if you have any external HDD or other device that drains power ans/or speed from USB ports. If you have it disconnect it and try again. BR AC |
04-28-2008, 13:46 | #5 (permalink) |
Registered User Join Date: Dec 2007 Location: cambodia,poi pet
Member: 648596 Status: Offline Thanks Meter: 13 | I think you have no need to cahnge any power supply or mother board... , try these step : 1- Check your USB power jumper ( open your PC case and Around the USB Connector, it should have a jumper with 3 pins, and you have to check it all. in this 3 pin, all of its must have 5Volt or better. or you can replace the jumper to another one ) 2. Try to use shorter cable. with this box. the cable should not longer than 2 meeters. 3- Do not use the Externals USB. ( Exept it have a external power supply ) PM me if your problem is not sloved. Best regard, Boreyphone.com |
plz Mr.elco take a look at this | ALGERIEN | NSPRO | 7 | 02-10-2010 01:28 |
i cant flash 6210,plz take a look at the error | .:M@ster:. | BlackBerry (RIM) | 3 | 10-03-2008 00:46 |
Pls look at my problem multi-team | islam01 | Multi-Box | 3 | 01-27-2008 09:55 |
Pls Multi Team look at my problem | islam01 | Chinese Cocktail | 1 | 01-03-2008 16:34 |
